Old August 5th, 2009, 09:04 AM   #1 (permalink)
smoke's Avatar
Bending the Hipshot Bender Bar
Anyone had any luck bending the Hipshot b-bender lever to bring it closer to the body? I am finding mine sits a little far out for where I wear my guitar, maybe an inch or two from where it would be most comfortable.
I am guessing bending it, even a few inches would be pretty tough since the bar seems solid. I would love to hear anyone's experience w/ doing something like this, if it works, if it impacted the unit, etc.
Thanks.
j
Apostle of telecasters.
smoke is offline   Reply With Quote
Old August 5th, 2009, 09:48 AM   #2 (permalink)
You can insert that z-shaped bar in different orientations so that it's closer (or further away) from your body. When I had one, I'd fix it one way for standing and another way or sitting.
ironweed is offline   Reply With Quote
Old August 5th, 2009, 10:11 AM   #3 (permalink)
smoke's Avatar
IW, I appreciate the response. I have tried it just about every way and I still find it to be a little too far away. I think just an inch or two would make a world of difference.
I am a slim guy so maybe I just need to drink a few more beers?
Old August 5th, 2009, 11:50 AM   #4 (permalink)
Wow, you must really be slim..........
I have to have my bar turned out so it's in the most "outer" position. I guess I'm a "f@t @$$" or something......... You might try something like wrapping something around the lever to give it more mass..........JH in Va.
Ralph Mooney rules!!
J. Hayes is offline   Reply With Quote
Old August 5th, 2009, 12:08 PM   #5 (permalink)
How about calling Hipshot, and asking if they can help you out? They might be able to supply you with some unbent hex stock.
jmiles is offline   Reply With Quote
Old August 5th, 2009, 01:09 PM   #6 (permalink)
helle_man's Avatar
I would second that...
I would second that. I think you'd probably be able to put the Z-bar in a vise and bend it to a wider setting, but I would call Hipshot first. They may even be able to offer another, better way.
WR
Will Ray says - "More Guitars, Less War".
helle_man is offline   Reply With Quote
Old August 5th, 2009, 01:32 PM   #7 (permalink)
smoke's Avatar
Damn good idea guys. Thanks so much.
Old August 6th, 2009, 12:32 PM   #8 (permalink)
Still trying to be helpful....
Did you try inserting it where the bend in the bar went back and behind the body? Maybe then it will hit you in the ribs instead of the butt, but will definitely move the "push-point" inwards.
Did you try tightening your strap, so that the guitar will hang differently?
Old August 19th, 2009, 04:23 PM   #9 (permalink)
tomtheguitarguy's Avatar
Perhaps there is some foam "tubing" that you can find that would give the lever added girth? Just an idea.
http://www.TomTheGuitarGuy.com ~ http://www.TomCatsBand.Com
G & L Will Ray Signature ASAT
CIJ Blue Floral w/ McVay G Bender
52RI w/ Hipshot B-Bender
RxES 2x12 ~ Carmen Ghia 2x10
tomtheguitarguy is offline   Reply With Quote
Old August 19th, 2009, 04:36 PM   #10 (permalink)
HOBBSTER01's Avatar
Hell, I left mine at home once and ended up using a large Allen wrench.
The Hobbster
HOBBSTER01 is offline   Reply With Quote
Old August 21st, 2009, 09:12 AM   #11 (permalink)
smoke's Avatar
Tom, that is a great idea. I haven't bent it yet because I have been playing my 62ri instead of the b-bender'd tele. I might hit up the hardware store and see if I can find some kind of foam, tubing, etc. Thanks for all of the help fellas.
Old August 21st, 2009, 11:36 AM   #12 (permalink)
been watching this topic for a while...am a little puzzled as to why the "stock bar" is not getting into a position that will work?; i've been using the hipshot bender for years and was pretty darn thin when i first started using one (i got over the being thin part, tho!!).....all that aside, i have seen some guys take a rubber ball and place on the end of the bar..i have one hipshot rig i have never mounted yet that has what looks like a screwdriver handle on the end of the bar/handle; dunno if it is factory or what since i snagged it used off the "Bay" couple years ago..good luck with it all..
bender-freak
bender-freak is offline   Reply With Quote
Old August 21st, 2009, 11:50 AM   #13 (permalink)
smoke's Avatar
Bender, probably a combo of where I have to wear my guitar for the voicings I favor (close interval stuff) and my desire to have it RIGHT next to me for quicker access. It is fine for the majority of uses now, but I want it literally directly available. Some great advice on this post, which I appreciate a lot.
Old August 21st, 2009, 03:26 PM   #14 (permalink)
Look for the foam pipe insulation used on 1/4" copper tube. That should slide onto the Hipshot lever. Then check out the foam for 1/2" or 3/4" tubing to put on top of the first layer. ie; build it up in layers.
how much for used hipshot b-bender? Guitartom_ca B-Bender Forum 3 June 21st, 2008 08:11 PM
Quadruple Bender/Bending setup??? B-Bender, G-Bender, E-bender/lever, etc. Screenery B-Bender Forum 9 May 24th, 2008 06:28 AM
Help with Hipshot B-Bender vjf1968 B-Bender Forum 7 January 12th, 2008 02:00 PM
Hipshot B-bender Hwilliams Tele-Tech 2 April 7th, 2003 05:02 PM
