Old July 28th, 2009, 05:55 PM   #1 (permalink)
richey88's Avatar
Help! My Bender only goes barely a half step
Hi Gang! My 1st post please be gentle.....seriously, need some help from experienced B-Benders here. I just acquired this:
(please excuse the crummy pics)
Anyhoo, she's a 97 USA if I'm reading the s/n right (N 7xxxxxxxxx), got some battle scars, but the neck is straight, frets have about 85% life left, Fender noisless pickups (prolly not for long). The bender however, barely gives me a half step with the #/b wheel all the way to the #, way less (so much ya barely notice) with the wheel all the way towards the flat symbol. What gives? I would think I should have at least a whole step of bend right?
Any suggestions/advice is appreciated. Richey
richey88 is offline   Reply With Quote
Old July 29th, 2009, 12:09 AM   #2 (permalink)
Dogbear's Avatar
You might want to remove the bender from the guitar by just removing the B string, removing the screws on the outside edge of the bender plate (11 screws) and pull the bender off the guitar. Then check to make sure that the middle brass block moves up and down when the thumb wheel screw is turned in both directions. The bottom brass block is fixed to the plate as is the top one. It should be easy to see if there is a problem if that middle block doesn't move. Bottom unit in the picture is a Fender, top is a Hipshot. They work the same way. Let us know what you find.
"Sweet is the melody, so hard to come by. It's so hard to make every note bend just right."
Iris Dement
Dogbear is offline   Reply With Quote
Old July 29th, 2009, 09:07 AM   #3 (permalink)
richey88's Avatar
Cool thanks......Nice pix, much appreciated!
Old August 19th, 2009, 12:44 AM   #4 (permalink)
Ormond's Avatar
Yes...take it apart and your problem should become obvious. DO NOT REMOVE THE MIDDLE SCREWS LIKE I DID! The damn guitar exploded on me when I took out the screw that holds the spring in place. It was such a mess that I put the guitar away for 8 years before I got it out to deal with it. Stretching that spring back into place is a *****.
Ormond is online now   Reply With Quote
Old August 19th, 2009, 10:32 AM   #5 (permalink)
You are aware that the thumb knob on the back of the bender unit adjust how far the bender bends. Turn it one way it goes sharper, turn it the other way it goes flatter. If you haven't tried this yet, I wouldn't remove the bender cover. I apologize if you already knew this, but this could be the easiest solution.
NEVERMIND, I SHOULD HAVE READ YOUR ENTIRE POST BEFORE I COMMENTED. I did not know you had already tried the #/b wheel.
threadbare is offline   Reply With Quote
Old August 20th, 2009, 08:30 PM   #6 (permalink)
Valvey's Avatar
Here's the go-to page for problems with that Parsons/Green bender.
Valvey is offline   Reply With Quote
tune down a half step, whole new (and better) tele! dusty tolex Telecaster Discussion Forum 28 June 1st, 2009 04:44 AM
Do you love chords with notes half a step apart two? upinthemteles Tab, Tips, Theory and Technique 12 May 14th, 2009 11:12 PM
Jimi's half step Dirty Steve Tab, Tips, Theory and Technique 18 March 11th, 2009 11:46 PM
Tuning half a step down J-man Bad Dog Cafe 17 April 27th, 2007 03:43 AM
Tuning half step Down to Get to Twangsville Platefire Telecaster Discussion Forum 7 December 18th, 2005 02:27 AM
