Old June 22nd, 2009, 12:15 PM   #1 (permalink)
Home brew B bender, here it is!
At last this is up and running, after weeks of head scratching and much work. Turned out pretty good, but my good lady has developed an aversion to sawdust and metal filings!.
Pics could be better, but you get the gist.
Specs:- Allparts TMO Fat neck, nitro finished, Kluson tuners, Tusq nut.
Self routed part douglas fir (Oregon pine), part pine, chambered body, Tru- oiled finish.
Voodoo TE50 bridge, Keystone Tele neck, pickups, 4 way switch. Mini toggle activates stealth Strat pickup, under leather pickguard.
Brass ferrule block (thanks for the idea Taipan) sits over brass bush carrier for back bearing of actuator, front bearing a small ball race in alloy carrier. Two additional small ball races provide front and back bearings for strap actuated lever. Length of throw adjustable (currently .9"), as is pull rod length and spring tension. The swivel bracket fixed to the top strap button is to lock off the bender mechanism via small knurled knob set screw. Two piece flush mounted plexiglass bender cover. All up weight 7lb 3oz.
JayBee is offline   Reply With Quote
Old June 22nd, 2009, 06:23 PM   #2 (permalink)
I like it. It has a very rustic Clarence White type vibe to it.
Chet Johnson is offline   Reply With Quote
Old June 22nd, 2009, 06:28 PM   #3 (permalink)
Thanks Chet, that was the idea and inspiration, from the start.
Old June 22nd, 2009, 10:27 PM   #4 (permalink)
HOBBSTER01's Avatar
I use my ironing board sometimes as a work bench too.
Good work.
The Hobbster
HOBBSTER01 is offline   Reply With Quote
Old June 24th, 2009, 12:41 PM   #5 (permalink)
asatfan's Avatar
Nice JayBee! I'm sure she's even sweeter knowing you did the whole job yourself.
"......gotta keep rockin' while I still can....." - Steve Earle
www.myspace.com/rugtheknuckleheads
asatfan is offline   Reply With Quote
Old June 27th, 2009, 11:02 PM   #6 (permalink)
City Sirens's Avatar
I would quake in fear trying to carve in the body by myself...
Play.
Alternate tuning blog
City Sirens is offline   Reply With Quote
Old June 28th, 2009, 06:00 AM   #7 (permalink)
BrianF's Avatar
It's just wood!
Old June 28th, 2009, 11:16 AM   #8 (permalink)
Dogbear's Avatar
+1
"Sweet is the melody, so hard to come by. It's so hard to make every note bend just right."
Iris Dement
Dogbear is offline   Reply With Quote
Old June 28th, 2009, 02:05 PM   #9 (permalink)
awesome looks great .. good work.
Guitartom_ca is offline   Reply With Quote
Home Brew Tele club Scotland Guitar Owners Clubs 67 Yesterday 12:46 PM
Home brew shielding paint? Cam Tele-Tech 2 July 18th, 2008 11:48 PM
Anybody home brew? FrankB Bad Dog Cafe 27 January 29th, 2007 07:41 PM
Evolution of a Home Brew BLACKCAT69 Telecaster Discussion Forum 1 June 14th, 2006 08:42 PM
Which pickup for home-brew Esquire? el_extranjero Tele-Tech 8 February 6th, 2005 08:25 PM
