Old June 10th, 2009, 03:33 AM   #1 (permalink)
Steel Voiced Chords?
I was looking for some steeley voiced chords to add to my playing, can anyone help?
Vikki(uk)
vikki is offline   Reply With Quote
Old June 11th, 2009, 09:38 PM   #2 (permalink)
Don Miller's Avatar
The harmonized scale on strings 2 and 4 works well. Try it in A..in some positions you will need to move the B string note down 2 frets so its in the right place when you engage the bender...it also helps if you slide from one position to another while engaging or disengaging the bender..play with it. The sixth intervals give some nice open steel-ish sounding chords.
One that I wear out alot is this...its on the B and high E strings...start with a D shape at 14, , slide to barre both at 10engage, disengage, slde to A7 at 9 engage , slide to barre both at 5 disengage,, and then do an Asus2 shape D and engage...hope that makes sense...its a D-A7-D move and works well in a Merle Haggard type tune...
Don Miller is offline   Reply With Quote
Which British-Voiced, 18 watt-ish amp for me? Iceman 420 Amp Central Station 52 May 12th, 2009 05:47 PM
Brit Voiced Speakers? Your Experiences? castpolymer Amp Central Station 11 April 5th, 2009 04:04 PM
Brit voiced speakers re-revisited 11 Gauge Amp Central Station 25 March 12th, 2009 05:34 PM
Is the Pro Jr considered a British voiced amp? Steve G Amp Central Station 28 December 31st, 2008 12:07 PM
Which Brit Voiced amp to get? 11 Gauge Amp Central Station 18 March 12th, 2005 01:35 PM
