Old May 17th, 2009, 03:43 PM   #1 (permalink)
Advice for drilling a hole for the B string in a Glendale bridge
I have an American Standard Parsons/Green bender that I am working on and I picked up a Glendale bridge with the American Standard holes. Do any of you have measurements for where the hole for the B string needs to go?
jdawg is offline   Reply With Quote
Old May 21st, 2009, 08:04 PM   #2 (permalink)
Any advice for how to do this would be very helpful.
Old May 22nd, 2009, 08:28 AM   #3 (permalink)
jd_elam's Avatar
For the last one I did, I used a 1/8" endmill and just milled a slot from the top of the lip on the bridge down to near the bottom. I used a block of delrin placed on the top side of the bridge so I could hold it in the vise without damaging the side rails of the bridgeplate.
jd_elam is offline   Reply With Quote
Old May 22nd, 2009, 04:05 PM   #4 (permalink)
Did you get left with any sharp edges on the top? Can't I drill a hole just to the left of the hole for the B/E saddle? That seems less intrusive to me but I noticed on Glendale's website that he just cuts a slot straight down from the top, which seems similar to what you're talking about.
Old May 22nd, 2009, 04:43 PM   #5 (permalink)
BrianF's Avatar
Either way..drill a hole or cut a slot works just fine. All you want to make sure is that the B string does not contact the bridge metal in any way. There's really not much to it other than that. I routinely just cut a slot with a Dremel tool with grinding wheel disc cutter bit. Make sure you wear eye protection etc.
Old May 22nd, 2009, 05:40 PM   #6 (permalink)
Freight Twang's Avatar
Yep, what Brian said!
Freight Twang is offline   Reply With Quote
Bridge Conversion - 3-Hole 6-Saddle Top-Mount to 3-Saddle Glendale String-Through radio Tele-Tech 20 April 19th, 2009 09:58 PM
Hardtail Bridge string hole spacings.. JBjr Stratocaster Discussion Forum 1 December 23rd, 2008 03:33 AM
**Drilling Toploader Bridge For String Through** jwells393 Tele-Tech 5 February 25th, 2008 06:45 PM
hardtail strat bridge - string spacing & string hole body routing question appar111 Tele-Tech 0 January 4th, 2008 01:02 PM
Bridge/string hole placement? Tedecaster Telecaster Discussion Forum 5 January 16th, 2006 04:14 PM
