Bustin' my B-string
Recently got a 2000 AM Series B-Bender...love it...but I'm bustin' my b-string every couple hours of play...anything I can do? What's your guys experience with bustin' your b's?
Not all who wander are lost. -- JRR Tolkien |
Do they keep breaking at the same place on the string? The usual places are (1) where the string meets the saddle, and (2) 1½" from the ball end of the string, which is where the string comes off the pendulum assembly on the bender.
If it is at the saddle, you probably have a rough spot on the saddle. Smooth carefully with either 800 grit paper, emory cloth and/or fine steel wool. When you polish with steel wool, be sure to protect the magnetic bridge pickup from picking up stool wool dust, hassle to remove! Put a tiny drop of your favorite bender lubricant where the B-dtring travels over the saddle with a toothpick each time you change strings. I use 3-in-1 household oil, but others have their favorites. Here is a discussion of saddle problems on bender guitars: http://www.clarencewhiteforum.com/cg...c&f=6&t=000219 If the breaks are at the pendulum, check out Gene's tech page for the Parsons Green bender on your guitar: http://www.stringbender.com/Bender/FBBtec.htm where the problem is specifically addressed. Hope this helps. |
