| Amp Owners Clubs Here you'll find owners club threads for many different custom amps and special model amps from larger manufacturers, too. |
#361 (permalink) |
Ya, and if you want one that is more likely to pull it's weight in those situations, then the SCXD is there. The Vibro is really meant to stay at home.
#362 (permalink) | |
The VHT Special 6 would be worth a look if it had on-board efx. Oh, well. Looking more and more like a Roland Cube 40XL is in my future.
Telecaster > Mustang Floor > FOH/BJr III/HRDx III/V1512T |
#363 (permalink) |
The best $150 gear purchase EVER!
I picked up the Vibro Champ XD at my local Sam Ash for $150, just a crazy great deal. I've been wanting a SCXD or VCXD for awhile just never pulled the trigger. After reading the thread I see I'm not the only one who can't believe how good these sound & what a deal they are at a buck-fifty!
When I played the SCXD in Sam's awhile back I noticed on Channel 1 it had some tube compression artifacts going on when picked aggressively, i.e. the ”tacky”, compressed sound one gets from only tubes. I been putting the VCXD through it's paces and haven't encountered that subtle effect with it. Anyone know what I'm saying? Aside from that difference, both models kickass with the Vibro really fitting the bill nicely as an apartment amp. I can get a great blues overdrive going on Ch. 3, Gain around 2, Vol. on 2 to 4 depending on time of day. Just a stellar amp no matter the size or cost... |
#365 (permalink) | |
#367 (permalink) |
Finally got one! Found one locally in near-mint condition for $100.
I'm loving it. I really doubt I'll use too much more than voice 1 and 2 (maybe 4) and some reverb but it's perfect for home practice. I just practiced through it for about an hour with my regular pedalboard and it was great. Just the right volume and way more plug and play than my Mustang 1. As I posted in another thread, I swapped out the Fender 12ax7 with an EH 12at7 and that seemed to smooth it out a little on voice 1 (or could just be my imagination). I think I have an EH 6v6 knocking around somewhere so when I find it I'll see if that makes any difference. Anyone swap the power tube on these guys? Try a 6L6 in it? I also ordered a Jensen Mod8-20. For $24 bucks shipped I figured what the hell it was worth a shot. I'm sure this thing will sound awesome though a 2x12 but I'd like to get it sounding as good as I can with out an extension cab. |
#368 (permalink) |
I have a weber in mine now but was wondering how important the speaker actually is. Since it is a modeling amp would putting a PA type speaker that doesn't color the sound in it, help the setting com through more.
#371 (permalink) | |
Also worth noting that if you're using the lineout then you're not getting any of the 'tube' sound from the amp, so it's similar to running a digital modeller directly into a PA. |
#372 (permalink) |
Jensen Mod8-20 is in and in.
Certainly changed things a bit. Not sure if it's an improvement yet. Seems like it tripled the bass but it muddied up the highs. I wonder if that will change as it breaks in and loosens up? |
#373 (permalink) |
So I've been following this thread and was just wondering if somebody can give me a solid recommendation on a speaker. I'm just not that impressed with the weber sig8 that I have in there now out of a champ that is RIP.
#374 (permalink) |
I toyed with changing the speaker on VCXD for a long time (over a year) and just kept playing it here and there between other amps. Low and behold the speaker opened up one day a couple of weeks ago after running the line out into an old 90's model Princeton Chorus solid state amp using the SC as a pre-amp/effects. The VC speaker was on the whole time, so I got a stereo effect. This sounded really good. The Princeton has two 10 inch Jensens in it. After unplugging the two amps I didn't play the VC for a while. Two days ago I turned it on and good things were going on. This was probably coincidental, but it makes a good story. Just keep playing it before paying out for another speaker and if it doesn't open up after a few months then get another speaker.
#375 (permalink) | |
I got an ES-295 too & wanna put in the GFS Nashville Vintage Filtertron. Which pickup ring should i use? Any other things i should pay attention to? Thanks! |
#376 (permalink) | |
#377 (permalink) |
Hi VCXD owners. I am making a cover for someone and I dont think he is measuring the handle specs correctly.
Would someone be kind enough to measure the following: handle length handle width distance from handle to back edge distance from handle to side edge Thanks heaps! |
#378 (permalink) | |
The VCXD, on the other hand, has a class A output stage (all single output tube guitar amps are pure class A). Class A output stages draw exactly the same amount of current from the power supply whether they're idling, whispering, or screaming at maximum volume. That's why they're terribly inefficient, electrically speaking - they draw full power even when they're silent. Because the class A current draw stays constant and never changes, there is no power supply voltage sag, and therefore no compression to be heard. So what you're hearing is inherent to these two different types of amp output stages - it has nothing to do with the SCXD vs VCXD as such. You're never really going to get that type of compression from any Class A tube amp, including the VCXD. -Gnobuddy |
#379 (permalink) |
I'm getting ready to buy a VCXD. I also have a SCXD. I'm making a head cabinet for the SCXD and I was thinking I could mount the VCXD into the SCXD cabinet and use it with the SCXD 10" 8 ohm speaker.
Is there any reason I can't run the VCXD (which has a 4 ohm output) through the 8 ohm speaker? I have heard that going up (or doubling) the speaker ohm is not a problem though the volume will be cut.
. "Something entirely new in the electric Spanish guitar field..." |
#380 (permalink) |
are you completely sure there is no tube effect on the line out cos it sure sounds like there is .. and how come it doesn;t disengage the speaker . as though it has to run the speaker cos the tubes are still in play ???
