| Amp Owners Clubs Here you'll find owners club threads for many different custom amps and special model amps from larger manufacturers, too. |
#1741 (permalink) | |
#1742 (permalink) |
Disconnect and reconnect the connector going to the DSP board a few times and hit it with a bit of Caig cleaner. More times than not, that'll cure the DSP board problem. ;)
My band : www.theexecutivesmusic.com |
#1743 (permalink) |
Me too. The only rattles I experience are caused by paintings hanging on the walls and other non-amp things in the room when I crank up my SCXD.
#1744 (permalink) |
With all this DSP talk you guys are making me nervous about my now discontinued SCXD crapping out on me. I really like the amp and already have a mustang so not much point in getting an X2.
Sell them both I guess and consolidate but that requires effort.. |
#1745 (permalink) | |
I'm curious about this whole business of the DSP board being unreliable. It's hard to say how much is myth (fear of new technology?) and how much is real (actual statistics on failure of these boards). We do know for sure that a few people on this thread have experienced failure of the DSP boards, most recently Mr. Perch. The thing is, Texas Instruments (who makes the DSP chip in the SCXD) makes good quality products that are used in tons of audio equipment - chances are there's one in your home theatre receiver, maybe one in your car stereo, and so on. They're not known for failing. So if the DSP boards in the Fender amps are failing a lot, the problem is not in the DSP chips themselves, but rather something about the circuitry of this particular amp. If the DSP boards in the SCXD are failing at abnormal rates, my first guess would be that it has something to do with the power supply used in the SCXD. Perhaps spikes of high voltage from the tube power supplies are making their way into the low-voltage supply for the DSP board or something. Overvoltage - even very briefly - is one way to kill any integrated circuit instantly. This sort of thing would be fixable with some circuit changes. Someone would have to diagnose the exact problem, then work out a fix in the power supply circuitry. It's the sort of thing one would hope Fender Corp would do as part of their R&D. Whether or not FMIC improved the power supply for the X2, we do not know. Let's hope they did. My SCXD is now over two years old, and still going strong. It's probably one of my two favourite pieces of music gear (the other one being my Agile AS-820, my favourite guitar). If it died I would be out there looking for some sort of replacement amp very quickly. Fender has a 5-year warranty on the SCXD, so I should be covered for another three years - but if I had the choice, I probably would get an all-tube guitar amp, not because of reliability concerns, but because I've become convinced that it's the tubes that make the SCXD sound as good as it does, and not the modelling. -Gnobuddy |
#1746 (permalink) |
I have told people for years this is the best $279 I have spent musically. Probably have sold 5 or 6 of them for Fender. Had it now for 4 years, just replaced a pre amp tube. It rides in my music van as a spare amp next to the blues jr. If it was a little louder I would gig with it.
#1748 (permalink) | |
Perhaps I was a bit hasty, but the way the power supply caps are soldered to the SCXD board, I couldn't at first sight see a safe way to discharge them for working on the amp. So rather than plug the amp back in and recharge all those dangerous caps, and have to wait until they were all safely discharged again, I just used a digital voltmeter to verify they were already discharged, and then dived head-first into the amp reanimation project. There has been plenty of progress, and I've taken photos along the way. But I'm not yet at the point where I can declare the project was successful. I need a few more hours of time free and clear to concentrate on the project, and it's been hard to find them in the middle of the usual busy-ness of our daily lives. Instead I grab 20 minutes here and 30 minutes there when possible, and so progress is slow. -Gnobuddy |
#1749 (permalink) | |
#1750 (permalink) | |
They gave you a new amp without checking that the first one was dead? Wow, there's a level of trust in humanity you don't often see from a corporation these days. Particularly a corporation that has a guy inside the front door whose job is to check your receipt and purchases before you can even leave the building!
![]() It's been a long, tiring, and busy day, so I'm off to bed...ill prepared for tomorrow's guitar lesson. -Gnobuddy |
#1751 (permalink) |
I'm sure it's somewhere in this thread, but is it possible to run the line out to a soundboard and play with the speaker unplugged?
If they act too hip, you know they can't play ****. —Miles Davis |
#1753 (permalink) | |
One of these 8 ohm, 50 watt resistors will do the job nicely: http://www.mouser.com/ProductDetail/...2bQnuz76n7w%3d -Gnobuddy |
#1754 (permalink) |
Okay, I'm not seeing much comparison in this thread between the generation 1, and the output w/ cab on the x2 version. Specifically, is the volume very close (stock), or a does breakup tube sound on the x2 project at a louder volume for the same amount of tubey goodness?
Any side by side comparison reports (shootout), or other reference volume settings after comparing some of this?
Hammer On! |
#1755 (permalink) | ||
#1756 (permalink) | ||
#1757 (permalink) | |
Finally got Jensen in place
I tried previously to screw those bolts off in wrong way: one at time. I got much better screwdriver than my skinny one from friendly neighbor, and loosened those bolts little by little. That previously tough one came out as nothing! SCXD`s OEM Eminence had become much better sounding after i had played it 40-60 hours since December, but i am very happy i upgraded to Jensen P10R!!! It will get better too after played in, but it`s cleans are fabulous, and lows have not a hint of any farting in them. I have never before heard this quality cleans from my amps, maybe not even in many concerts of world famous rock groups i have visited since Beach Boys in Helsinki 1967. Even high gain tones are already fuller and nicer than before. I am after surf cleans mainly. Looks i have achieved my goal now! Gnobuddy, big thanks for your helpful attitude! Last edited by savofenno; April 12th, 2012 at 07:49 AM. |
#1758 (permalink) |
Did some one man jammin' with the John Mayer "Where the Light Is" concert video yesterday and suddenly (re)discovered voice 16. Using that with either the P90 or the bridge pickup on my telepartscaster (I added a P90 mid pickup) produced a nice acoustic like sound (like an acoustic recorded with a good microphone, I'll say).
Throughout that concert vid I mostly changed between ch1, ch2+v2 and ch2+v16. Single single coil pickups all the way (didn't combine pickups much). It was great to discover how well the tele and SCXD worked for this kind of music. It proved to me once more the versatility of both the telecaster and the SCXD. |
#1759 (permalink) | |
You're welcome, I'm glad I could help! -Gnobuddy |
#1760 (permalink) | |
Everything old is new again. -Gnobuddy |
