| Amp Owners Clubs Here you'll find owners club threads for many different custom amps and special model amps from larger manufacturers, too. |
#1361 (permalink) |
Finally got around to doing the LED mod, I can definitely recommend it. I like the way it doesn't start distorting now until the gain is really cranked up. And the boost switch is more usable.
#1362 (permalink) |
Here is a Pathfinder doing a nice job at The Station Inn, Nashville.
http://www.youtube.com/watch?v=1IpZOiNRARI |
#1363 (permalink) | |
Was your mod the same as shown in this thread?
Hammer On! |
#1364 (permalink) | |
i m thinking of that exact set up, i have two pathfinders in a stereo rig we use in rehearsal but i want to move into 12" cabs... I have no skill set, lol... would you consider building another unit like for retail? the other route would be to put them into a combo chassis --- does anyone know what fits? I think I read somewhere that a Blues JR would work... if you wired it up right with a speaker jack, the Blues Jr configuration could also be used as a cab with another amp head ( i have a tube 50/50 power amp head for bigger gigs. ) |
#1365 (permalink) | |
#1366 (permalink) | |
Someday I'll quote someone... |
#1368 (permalink) |
What makes you say that?
General James Ewell Brown "Jeb" Stuart ![]() General James Longstreet ![]() General John Bell Hood General Ambrose Powell Hill ![]() Oh, and I kinda resemble that remark.
Larry G The soon to be famous musician/Cranks out Top 40 tunes in a bar/While his mind is somewhere on vacation/Far away from his voice and guitar Bob Bennett |
#1370 (permalink) |
Just needed to see this thread back on top, where it belongs!
** BTW, folks looking for that "cranked Clapton Champ tone" (from the Delaney and Bonnie and Derek/Dominos days) can get pretty damn close for cheap with a Pathfinder(clock): Gain at 1:00, Volume at NOON, Bass at 10, Treble at 1:00-2:00, a Strat, and good fingers!: edit: Boost OFF
Tele/Tex-Mex Strat/Dano '56 U2>MHP "Stubble Trouble" FUZZ/MHP "perfected" GFS Brownie Classic/Barber Direct Drive/Blues Driver> MORE PEDALS> '68 Deluxe Reverb or blonde Blues Jr. Rock On! |
#1371 (permalink) |
Just obtained one two days ago and have enjoyed it quite a bit since. This is my first solid state amp since the '80's, other than stereo equipment. I have been keeping both the bass and treble levels low and have been impressed enough by the low key spring reverb, a key element that attracted me to the amp. An old block MXR Dyna Comp did a good job of helping trick me into feeling that I was playing a tube amp, was not motivated yet to throw a lot of pedals at the amp...and that is a compliment.
Is anyone using 4 ohm cabinets with their Pathfinders? I actually like the stock speaker, so far but prefer options. With a 4 ohm load, I could run either a 15" EV in a sealed Peavey cabinet, two 12"'s and 2 horns in two Fender 8 ohm PA cabinets, or a Leslie 825, that was stripped of its amp, but it has a 4 ohm speaker. I love all of the options with my silver Fender Vibro Champ and hope to do the same while using the Pathfinder without messing it up. Yikes....nearly forgot a few Weber 8 inch/4 ohm speakers that I use with the Vibro Champ and a Bronco. Safety to the new amp is my concern. Thanks |
#1374 (permalink) |
Solid state amps aren't that picky in load, usually you can run them safely even without a speaker connected. But it's generally better to hook up a speaker with a higher rated impedance than a lower one.
I wouldn't worry about it. Not that tube amps are that picky by the way, they just don't like very high impedances (ie running without a speaker connected). |
#1375 (permalink) | ||
And I know this from first hand experience. I was swapping speakers and went back to the stock speaker, but forgot to hook the speaker back up. I turned it on and it started to emit a terrible smell, then a loud pop. It blew up the main amplifier chip. It was a pain to change, and for a time I thought it was never going to work again, but rigged it to work again. The problem is that the traces on the board are very thin, and when soldering the chip in, it melted the traces right off the board. Like they say on TV "Don't try this at home, kids!"
#1377 (permalink) | |
![]() Poster Extraordinaire
but the vox pr is a dandy (and sometimes, tasty) li'l s/s amp that i use daily to test out gear.
![]() fretted instrument tech ~ custom partscasters Cavalier Single Coil Pickups Molon Labe! |
#1378 (permalink) |
Yep its a cool sounding amp - but one that costs relative peanuts.
Some build costs cuts will inevitably invite caution. We ought not to be surprised I guess ! I get the strong impression that the Pathfinders are generally reliable if left relatively unmolested ;) |
