5e3 clean
Is this amps clean sound robust enough for gigging. I'm looking at building but the word about it's clean not being too good is scaring me.
Thanks ce24
www.motagator.net/slackwater "you can be happy or you can be miserable..the amount of work is the same" |
It depends on what kind of music you play. Keep in mind that the Fender tweed-era amps were raw sounding. They break up and distort when you either drive them hard or crank them up. Desirable features for classic rock and blues. If you play pure country and looking for a clean amp...you should be looking at more modern Fender design ...such as a blackface or silverface Fender..Twin Reverb, Deluxe Reverb, Vibrolux Reverb etc
My short answer for this is going to be no. With a drummer I would need about 30-35 watts minimum if I wanted clean.
I play tweeds exclusively and my main amp is a tweed deluxe. It really doesn't do clean in a band situation. Still, when mic'd it's perfect for my needs.
Just because I "Don't" get it doesn't mean I "Won't" get it! |
I can mic it.. I play in a duo but we use full backing tracks...Right now I use a Peavey c30.....we do country (a little bit), classic rock, blues ,pop..
thanks for the replies ce24
As much as I love my Hullett 5E3, if I need clean uber-clean, onstage or recording, I use my 5F4 Super. I DO get a great clean out of my 5E3 if I just back off the volume control a bit.
It'll be interesting to see, after our record is released, whether y'all think Tweeds are "raw." They can be and when cranked, they're the best kind of raw, but there are GREAT cleans to be found in some of the tweed circuits. My belief is most of the people who claim tweeds don't have good cleans are people who dime their guitars from the word go, and never touch their volume knobs. YMMV. |
Just mic it or if ya really like the sound of it line it out like I described in that line out post to an other amp for more clean vol. They do have a nice passable clean sound when not cranked. Like I keep saying that early classic country from the 50's had to come from Tweeds and amps like it thats all they had.
Loading it with an effiecient speaker can help a lot. I chose a Red Fang for my 5E3 build for that reason. Personally, I love the clean tone from tweed circuits.
With a mic on an efficient speaker, you might be just fine, especially in your situation (duo with backing tracks). Turn the stage volume down to keep the 5E3 clean and turn things back up through the PA.
Mark Flying blind on a rocket cycle. |
#12 (permalink) | |
ray |
In duo with a PA, I think a 5E3 would be fine for clean, if your PA can do the volume you need. As others here have said, there is a lot of tonal variety in a 5E3, from twang to fuzz, its just that the clean twang is in the low volume area of the amp and you may not have enough volume until you get dirty. I have gigged my 5E3 quite a bit playing instrumental surf, honkytonk country, classic rock and blues, all in the same set and it covered them all well, provided there was enough support from the PA.
#14 (permalink) |
I've settled the issue...I'm going to build the 5E3. I was seriously looking at a 70's Princeton Reverb. then I looked at my Bravo and it's rated at 25 watts and I only need it on 3 for volume so I'm sure the 5E3 at 18 Watts will be just fine. Yes using the guitar vol knob will be just that much more fun to play. I appreciate all the info and replies..I'll be ordering this week!!!My Agile tele has bill Lawrence 280/290's they are superbly clean so I should be a happy camper.
Cheers c24
I love the 5E3 circuit for what it is, but not for clean tones. It's not going to come anywhere near your Classic 30 for clean volume. The 5E3 will do some beautiful low volume cleans, but you will need a PA to boost it to gig levels.
#16 (permalink) | |
hth
clean as a whistle |
#17 (permalink) |
I love the clean tones. But, there is not much for head room. The speaker makes a huge difference with that amp clean in my perception. But, you need headroom you will have to mic it. A bigger issue may be the bass with it.
Guitars: Teles, LP, others. Amps: El Diablo, Richter 5E3, 5E3 Head, Traynor Bass Master II, Epi Jr Head, Gretsch/Supro, 60's Univox and others. Current Board-Guitar>Tuner>Java Boost> Huckleberry>Fuzz Head>Top Fuel>SFX-03> Keeley Comp>Clone Chorus>FL3> Amp |
#19 (permalink) | |
A duo? Yeah, especially mic'ed. Especially with you able to control the backing track volume. Especially with a Telecaster. Single coil pickups will OD a bit less. Especially with a 12AY7 in that first socket (like they used to be, folks these days use 12AX7s for more drive and gain). I like a raw, warm, ragged kinda "clean." Cleans that are almost dirty compress nicely. SF Fenders are just downright squeaky clean, some BF Fenders are a sorta "warm" clean, and tweeds are often a raunchy "sorta clean." Listen to 5E3 soundclips and you'll see they can still be clean. I will stop saying "especially" now... |
#20 (permalink) |
Anything can be clean if properly mic'd and your PA can handle it. But a Tweed Deluxe isn't really intended for cleans, ya know?
I have someone building me a 5e3 at this time. I'm not gigging right now, so my 35 watt Holland amp was collecting dust. I figured a 15 watter is more likely to work at home and with friends. If I ever get around to gigging again, I'd just mic it, need be. The Holland was great clean, as was my 73 Pro Reverb, but while the cleans were great, it's a lot of amp for your situation (as you're finding with the Classic 30). As someone here described, there are BF Fender cleans, SF cleans, and tweed "kinda" cleans. A big tweed amp (say a Bassman) can be pretty clean and loud, but it's when you get to that point of just pushing it beyond clean is when you start hearing (IMHO) it's best tones. The tweed Deluxe gets to that point at a much lower volume. If you have the PA power to mic the amp, I would think you'd rather run the risk of being slightly underpowered rather than really overpowered. An amp turned way down due to being overpowered for the room, to me, never brings out it's best tones. |
