Old February 24th, 2008, 04:54 PM   #1 (permalink)
Re- Tolex
Did Fender paint their amp cabinets before the Tolex was applied? I just removed the Tolex from an 80's Fender cab. and it looks like it was painted black....Does the bare wood need some kind of sealer applied before the glue?????
can't-play is offline   Reply With Quote
Old February 24th, 2008, 06:04 PM   #2 (permalink)
Ringo's Avatar
re sealer
I have recovered some old Fender amps where it did look like they painted the wood.
I usually do sand the wood to get it smooth and sometimes I'll spray some sealer on, or you can just paint it black , if you're going to paint the inside of the cab you might as well spray it all IMHO.
You don't have to seal the wood , I've done it both ways.
I use the stinky solvent base contact cement, I spray it on with a cheap quart spray gun, pressure around 40 lbs, works geat for me.
Old February 25th, 2008, 04:08 PM   #3 (permalink)
Thanks Ringo, I was going to paint or clear finish and use it until i retolex but did not know if the finish would have an adverse reaction to the glue..
vB code is On
Forums Directory
