#282 (permalink) | |
I think it sounds more like a Champ than anything else.
Don |
#283 (permalink) | |
Don |
#285 (permalink) |
Just out of curiosity, rather than go to the trouble of removing the rear grill, why not just leave the back off? Any reason other than cosmetic? Mine seems to sound better without the back.
The blues ain't about theory, they's about therapy. |
#288 (permalink) |
My first GA-5 is getting the full monty of circuit, speaker and cab mods, the second remains perfectly box stock - this affords some viable sonic A/B testing which I'll carefully record with a Zoom H2 and share on this thread.
I don't think it'll matter much at all if any or all of the grilles are removed - dittos for the removing the entire rear panel. CIRCUIT (as of 3/7) * 1m resistor and 22pf cap removed and jumpered * 1st stage 25uf cap lifted * 47k NFB added * 1/4" external 8 ohm speaker jack added * ground buss rewiring??? - more on this due from specialty SPEAKER * Weber 8F150 CAB * remove the power cord box * remove the rear grille * rebaffle with 1/2" birch ply and cane grille |
#289 (permalink) |
Sidney Vicious seems to think so.
The problem with this grill is that it's so dense. I would think that it would make some difference. It would be different if the amp was voiced with the grill in place. I believe it was an afterthought with these amps. Besides that, I'm a bit of a purist and don't like extra crap that doesn't belong there and bought this amp to mod and tweak anyway.
Don |
#290 (permalink) |
IMO, the rear grille is there for corporate protection, and the front grille insures a no-sag cloth front that's "poke proof". In terms of sonics, I still don't think the grilles will much matter, and with the stage of mods I've already done to GA-5 #1 it'd by hard to tell the difference with my stock GA-5 #2. The cane grille I'll be using will be tight as a drum and nearly as "poke proof" while allowing for quite large weave holes for the sound waves to escape.
#291 (permalink) |
Just pull mine outa the box, cute thing. Sounds pretty dang good w/ the volume at 5, it does get a little raspy on the top end but not too horrible.
For me it's not a gig amp but it's a fine workbench/utility amp, I've been using a Fender mini bassman (the old yellow plastic one) which will tell you that you've got a good circuit, but that's all, this will be a real improvement. I'll take it apart and try some of the mods mentioned when I get time, but I'm happy w/ the Gibby.
3. If they can get you asking the wrong questions, they don't have to worry about answers. - - Thomas Pynchon |
#292 (permalink) |
I believe the rear grill is there to make it certified CE to be sold in Europe. I believe they require that a grill or some other method be used so that there is no way that anyone could stick their hand anywhere and get burned by the tubes.
As far as that weird cord box, I have no idea. I'm guessing the speaker grill is to keep "little Billy" from sticking his foot or something else through the speaker. It does all seem a bit much, but such is life in a time when everyone must be protected from themselves. I wonder how many deaths and injuries occurred to guitar players in the 30s 40s 50s 60s and 70s before these modern safety features were required? Sure a lot of Vox amps caught on fire, but that's because they didn't have enough ventilation, because they were...over-enclosed. |
#293 (permalink) |
I am the first to admit that I may be hearing things with regard to the difference in the sound of the amp without the front metal grate - in fact I was the first to admit it in my original grate-removal post.
But having said that, I think my ears and mind are not fooling me - that grate would deflect a poke from a thown cue stick! Its as though it were designed to protect something much more irreplacable than a Weber Sig speaker . . . . I have several vintage Fender amps - as do many of us - that have nothing but a grill cloth protecting the speaker from the world. For whatever reason, Gibson decided that grill cloth is not enough. I have got to believe that at some point a grate of this sort has a deliterious (sp?) effect on the ability of the sound to escape. The rear grate is less important - I removed it so that I can put the cord in and out more easily. I believe the evidence indicates that heavy front metal grate was a late "improvement" to the amp's design - removing it in my view returns the amp to a purer form. |
#294 (permalink) |
If it originally had no rear grill or "cord box"... I wonder if the grill and "cord box" were added after a bunch of amps came in for service. It seems to me with a "computer style" electric cord that plugs into the amp vertically, you could do some damage if you grabbed the amp (to move it) and forgot to unplug it first.... the cord box will prevent some of that, and the grill prevents "re-routing" the cord. Just a guess - most computer style electrical cords plug in horizontally instead of vertically.
Save The Hymnals! |
#295 (permalink) |
I'm not saying y'all are crazy or nothing, but this fuss about the front grill seems way out of line. my other Gibson amp's got way more of a screen
![]() and it sounds just fine. Kind of like the GA-5's big brother, actually. Hey, maybe the screen's the secret! I'm going to go rob a confessional and put that screen in front of the speaker on my Bad Cat! I'll report back when I get out of jail. |
#296 (permalink) |
#297 (permalink) | |
Like most amps, the power cord on the GA-5 has screw retainer into the cab side for cord stress/strain relief. So the cord box serves some other purpose. |
#298 (permalink) | |
Look at the internal pics of the new Fender Deluxe reissue. It has a box around the input jacks.
Don |
#299 (permalink) | |
The tubes and transformers are completely exposed in the back with only an extruded aluminum bar to protect them (not you!). If you'd like to burn yourself on a hot 6L6, you're free to do so. Rock and roll is supposed to be dangerous!
Don |
#300 (permalink) |
I think it's just to prevent the plug from going all the way back into the cab so you can't grab it. With the grill in place in back, there's no other access, so you'd have to try to reach in through that little hole and fish around with your finger to try and hook the damn thing out.
#301 (permalink) |
Hiya everyone, I've got a GA-5 gig report to share...I had been looking to help bring down our stage volume a bit, so I jumped on this little amp. It's all stock, I don't know a thing about all the wonderful mods you have been chatting about! I did swap out the 12AX7 with a 12AT7 to see if I could get a little more clean headroom...here's my report:
Played a small venue last night, brought this new little gem. Small stage. House held about 100. We are keyboards, bass, drums, and guitar; a Louisiana style zydeco/funk band. This amp kept up really well, everyone in the band liked it! I put a SM57 on it and sent it through the PA. Up on an amp stand, just next to me, angled across the stage like a monitor. At one point, my bass player stepped back outta line with this thing when I took a solo later in the night (when our volume started to get up there!) It was too loud for her! This thing is just great for me. Lightweight, packs a great punch. Not a ton of 'at volume' clean headroom, so that was an adjustment. I never once used my Blues Driver, so unnecessary. It was all about twiddling the volume knob on my Strat. I kept the amp around noon or 1 o'clock, never touched it all night. I did use an EQ pedal to give it more high end, and that worked great, I kept it on all night. Overall, I'm very happy with it and looking forward to gigging it again. In a live situation, there's a learning curve for me when it comes to getting my gain at the guitar, and dialing down for clean. This made it very fun and satisfying to play, a whole new ball game! droo |
#302 (permalink) | |
Out of curiosity does this amp have the CE symbol on it anywhere? |
#304 (permalink) |
I'm waiting for Rob's A/B clips. Mine sounds pretty sweet out of the box. No body seems to talk about the room size, furnishings, ambient sound, etc. All real world variables which shape and color sound, possibly negating various "mods".
Support our Troops |
