#161 (permalink) |
They're made in USA regardless of what you may have heard.
Sure it has some imported parts and subassemblies, but what doesn't? A Ford Mustang has more imported content than a US built Toyota Camry! As far as the closeout pricing is concerned- I'm sure that Gibson has a huge number of these that they have to liquidate in order to continue their merger with TC.
Don Last edited by red57strat : March 3rd, 2008 at 01:53 PM. Reason: spelling |
#163 (permalink) |
Waiting for Robbie D to chime back in - I just KNOW he's up to something having discovered that 8 ohm tap . . . .
Meanwhile, I'm debating pulling the trigger on another one of these cuties. Anybody know how many are left? Should I wait for a returned discounted item? |
#164 (permalink) |
I've got one of these on the way, should be here her Thursday. I need another amp like I need another guitar, but I figured what the hell...
I couldn't build a comparable amp for anything close to that price, and can mod anything on it that I want to dial it in, so it seems like a winner. First thing I see is that since it has solid state rectification, there's no possibility of using an indirectly-heated cathode tube rectifier to make up for the lack of a standby switch, so a standby switch mod is in order to increase tube life. |
#165 (permalink) | |
200 left
This is not me http://www.youtube.com/watch?v=PhnhBltrI6k |
#167 (permalink) |
You know, it would.
You'd need to drill a hole for another octal socket, but that's doable. If the PT has the 5 volt tap, you could use a GZ34, but if not, you could use Weber's Copper Cap version. It has the delayed warm up, that would help the other tubes. Excellent idea! |
#168 (permalink) | |
#169 (permalink) |
I noticed that the amp is louder and better sounding without the back panel on. The mesh appears to restrict the sound.
Then I noticed that the speaker grill cloth is hard. There's an even more dense (very dense!) steel mesh in the grill. I bet the amp would really open up with both steel meshes removed.
Don |
#171 (permalink) | |
I'm not sure what I plan on doing yet. It sounds great. I thought about throwing a 10" in there. It will just squeeze in, since the cage is able to slide in that small open space between the cab & chassis. I'm also thinking of building a 1X12" cab and putting the GA-5 chassis in that. I had to ditch the 12AX7. Way too much drive with my Strat pickups. I replaced it with an AT7 and it's MUCH better but it's still seems like a lot. I'm ordering some AY7's and lower tonight. This amp is voiced perfectly for my bridge pickups, but a little dark on the middle and neck pickups. I'll find a way to even everything out soon. I just opened the package 3 hours ago so I've mostly been playing the thing. |
#173 (permalink) |
I haven't even been to this site in the last 6 months because i've been at college and didn't bring my electric with me. But i stop by to check stuff out and THIS?!?! i ordered one, or rather i had my dad spot me for one, it's coming by the end of the week! my first legit tube amp! i'm only slightly excited.
Don't you dare tell me "you get what you pay for." |
#175 (permalink) | |
Exactly. All my tube amps sport Carling 3-ways for off/standby/on - aside from the rewiring, it'd be a direct replacement in the GA-5 for the existing 2-way without having to drill another control faceplate hole. I don't see a need (right now) to mod the diode rectifier, particularly if a standby is added. Those mesh grilles - front and rear - beg to be removed, and the cord box needs demolition. I'm gonna add a 1/4" 8 ohm speaker jack to run an external cab (since the Heyboer OT is 4/8 ohm tapped). The JenNeo 2x12 I'm building will be a nice tonal experiment. A 10" will fit, but it will be partially blocked by the baffle's TV front. I have a hefty 8 ohm Weber Chicago Vintage CTC-10" that should be sweet for this amp. Now all I need is the TIME to fiddle with this GA-5, while awaiting another to arrive! |
#176 (permalink) | |
Is the front mesh stapled in similar fashion to the rear? Do you think that the metal grill - front and/or rear - is sonically choking the amp? I would think it would have no effect - unlike say a heavy cloth grill. Or is removal a convenience thing, as I know the cord cubby hole is tight. (edited for clarity) Last edited by Sidney Vicious : March 4th, 2008 at 08:13 AM. |
#177 (permalink) |
The mesh panels have to be restricting the amp somewhat.
The front mesh on mine is much finer that the rear mesh. It's appears to be more than 50% occluded! They did some nasty, though reversable, things to these amps to make them "safer". Safer for theire lawyers, that is! The cord box on mine is held in with glue and small nails from the inside. It will come out easily. The rear mesh will also be easy to remove. The front mesh will be more difficult because the grill cloth will need to be removed and put back on. A pair of Switchcraft jacks to replace the plastic jacks would be nice too, but I won't do that unless I have some on hand or happen to be ordering something else. This nice little amp could be turned into a great little amp with a few free and/or very inexpensive mods that won't really change it's character but will allow it to perform it's best.
Don |
#178 (permalink) |
I removed the screen from the back panel the other day in preperation for hooking up my 2x10 cab. The RCA>1/4 adapter I ordered from Weber is sitting on my front porch right now and I'll be pissin' off my wife and neighbors as soon as I get home!
Jonathan - Demos@purevolume.com When the power of love overcomes the love of power, the world will know peace. - Jimi All I need is my Esquire - MM |
#179 (permalink) | |
Or is it a one or the other kind of thing? |
#181 (permalink) |
Who else besides MF is blowing these out?
I just tried Sweetwater (out of stock) and ZZounds (unable to price match)--any one got other leads for the 299 price. If I do have to go MF, what's the scoop on coupons??
too many guitars... |
