#801 (permalink) |
Tried an alnico speaker -
I have an old vintage Jensen alnico speaker - an 8J11 - from a Harmony H400 amp -
(having owned a couple of the H400's I can tell you w/o fear of contradiction that the Jensen speakers are the best part of those amps) - anyway, stuck it in my GA-5 - stock except for removal of the wire meshes and wood cord box - and I like the sound of it very much! Based on a quick test run I find the Jensen less efficient and the sound of the amp fuller and more articulate at a lower volume - does that make sense? The break is just as sweet - again, though, at what I perceive to be a lower volume than the stock Goldtone/Weber. With the Weber it seemed I would kinda hunt for a sweet spot in the guitar/amp volume settings. The Jensen sounds "better" throughout the dial. Admittedly, the Weber is not broken in - the Jensen is 40 plus years old! A few years ago when I had my first flirt with cheap Harmony amps I learned that the 8J11 was stock on some vintage Gibson amps - maybe something to do with it? Anyway, I'll leave it in for now. |
#802 (permalink) |
Mine arrived last night.
I have been playing the past couple years through a solid state with a 12 inch speaker, so my first reaction was "oh!" Quite a difference! I had forgotten what tubes felt like! After, I tried the gain channel on the solid state and realised how nasty it sounds. I will say though that I prefer the Kustom 12 Gauge clean sound , because of the 12 inch speaker, and it also has a sparkle. But with the volume down on the guitar , you can get almost the sound. In fact, if you have a guitar with a volume and tone knob, and a good reverb pedal... (or whatever other effects you enjoy) , then I think you can use this amp in a number of versatile ways. I really like this amp. As is , with no mods at all, i'm quite satisfied. Some advice, if I may,... if you live in a close quaters apt. building with paper-thin walls... think twice before buying this amp! It wants to be turned up, and it is stinkin LOUD! I'm having issues with this already. |
#803 (permalink) | |
I don't know what was typically used in Harmonys, but It looks like vintage Gibsons typically used 8 ohm 8"s. |
#805 (permalink) | |
#806 (permalink) |
Some quickee sound bytes comparing a box-stock GA-5, then modding that same GA-5 with only the trinity mods. Vol set at noon.
Quite diff'rent tones - the stock amp has that raw, raunchy, louder energy whereas the modded amp is more laid back, mellowed and lower volume. Lifting the NFB adds back a good measure of that rock 'n' roll tone (as I've done with my modded GA-5). Same Strat as before, mic'd with a Zoom H2 in stereo at about 12" off the Sig 8 speaker cone. The first rock licks are picked using the Keystone bridge pickup, the second ragtime tune is fingerpicked using the neck L200 noiseless pickup. 6 meg WAV file ... Stock GA-5 6.7 meg WAV file ... Trinity GA-5 |
#809 (permalink) | |
Rob, Tasty playing! Your clips play muddy for for me. Is this something on my end, or the way the clips are recorded? |
#810 (permalink) |
Hmmm, don't hear that on my end. They're crisp WAV files, and there is is some goodly breakup happening (with the amp pushed halfway), particularly on the plectrum stuff, and very little on the fingerpicked stuff. Dunno ...
#811 (permalink) |
Good question. The 8F150 has the largest mag ring of any Weber 8" and the EL84's spring retainer hits it a bit - bending or removing the retainer would allow that speaker to fit. I think the Blue Pup's mag ring is a tad smaller ... ?
#812 (permalink) |
Heck - did a little Googling -
and it seems the 8J11 was stock in the Gibson Skylark - you know, the original GA-5! (scroll down and you'll find it - and find a lot of other cool Gibson amp info along the way) http://www.harmonicamasterclass.com/vintage_amps.htm |
#813 (permalink) |
For guys like me who haven't used in years, and are not interested in using a soldering iron anymore, I recommend a eq pedal.
I've also experimented with my Digitech RP 150 and it sounds terrific. With an eq you can make it sound great! no muss - no fuss! |
#815 (permalink) |
yea Rob, I know what you mean, but I have 6 thumbs. It is interesting to read what you have done , and it sounds great. Great work!
As for me, i'll have to make the best of it here, but it does sound quite good... i'm happy! |
#817 (permalink) |
Nice playing in those clips Rob.
I think cutting back on the negative feedback by about half would be just perfect...anyone know what value resistor that would be? My "vintage" Sozo caps showed up today so I stuck them in the amp and let them burn in a couple of hours. Compared to the Mallory 150s the amps sounds a little more clear in the mids and more "eager" if that makes sense. Notes seem to jump out of the amp. Well worth the few bucks. |
#818 (permalink) | |
If the clips sound correct to you and everyone else, it must be this computer's WMP. |
#819 (permalink) | |
Why not replace the NFB resistor with trim pot, say 100K, 200K? Then dial in what sounds best? |
#820 (permalink) |
If you want half the amount of NFB, you'll have to experiment with higher value resistors. If you have a 47k in it now, which is is the mod that I prescribed, that is the same value the vintage GA5 had, try a 100K and see what you think. Then work your way up or down in resistor value from there. The higher the resistor value, the less NFB.
#822 (permalink) |
Not good at all - WAY too much bottom end. The 8F150 might be best in the stock GA-5, not in the modded one without the NFB and with the 1st two trinity mods accomplished. I think the perfect "standard" speaker for this amp might just the AlNiCo Blue Pup or the CVA8.
