#561 (permalink) |
I just looked at the hit count for this thread, and it is almost 15,000.
Can you believe this many Tele players are keen on learning about and sharing info on this little small-run Gibson amp? Quite a surprise to me! Mine is due in tomorrow's mail, right when I leave town for a week. As soon as I get back, I look forward to trying some of these great tips. |
#562 (permalink) |
Didn't take much to damage the Sig 8, but then again that speaker is a mini mouse compared to a quality 8" driver. I should have the 8F150 arrive and installed tomorrow - that should be the ticket to handle the horsepower this li'l amp dishes out (with the mods, of course).
#563 (permalink) | |
It is not just about this one amp; it is about an excellent environment for those of us (like me) that have been around these things but never learned what was really going on inside, and have discovered some we'd like to know more.
Bubban0v |
#568 (permalink) |
Gigged again last night with the GA5....very impressed. Hung in there no problem, it was a medium sized St. Paddy's Day restaurant gig, around 200 people or so. I mic'ed it through the PA, worked great. Put a SM57 on it.
As for stage volume, it was no problem hearing during solos, but funky rhythm parts were harder to hear as clearly as my Delta Blues, of course. I solved this problem by raising it up high on the amp stand, got it about waist level. After that, I could hear it all, and the band commented on how nice it worked! For those of you who think this little bugger won't be appropriate for a gig, I'd try it out. I probably won't be using it at festivals this summer, as it obviously won't fill a large stage with sound....but for casuals and clubs where it's a tight stage, boy this thing just smokes! Put a mic on it, and all is well :) I hope ya'll are enjoying yours too :) droo |
#569 (permalink) |
The Weber 8F150 just arrived and I pulled the farty Sig 8 and dropped in the big boy. As you can see by the images, the chassis fully clears the 8F ... the EL84 spring retainer ever so slightly touches the big ring magnet, but that could easily be tweaked/bent out of the way (or just removed). Of course, I'll build a totally new baffle board and cane grille it.
#570 (permalink) |
gone, gone, gone
music 123 shows them on their website & will let you order them -- but it shows up in the cart as a special order / not in stock item . . .
Wouldn't surprise me to hear that a pile of 'em turned up somewhere, most likely at MF (music 123 is just MF in a wig). I bet you'll hear it here first, though not til Rob D has ordered #3, #4, #5 and #6. Keep your eyes peeled. Pretty likable little amp, better as time goes on & the speaker breaks in. |
#571 (permalink) | |
#573 (permalink) |
#574 (permalink) | |
As I described in an earlier post on this thread, it'll take some speaker and/or chassis tweaking to fit in a 10". Anyhoo, the new baffle has been sprayed and is drying. I lowered the speaker hole by 1/4", right down to the lip edge of the TV front. The speaker screws are recessed thanx to a Forstner bit, then CYA'd 'em in. After the paint dries I'll staple on the cane grille and that's about it. ![]() ![]() ![]() |
#575 (permalink) |
I wasn't questioning your experience.
One thing where I keep going wrong, is looking from behind, I forget that it is not a narrow panel tweed cab, and that the speaker actually can't really be moved very much, as you mentioned. |
#576 (permalink) | |
The cab spex and design pretty much dictate sticking with 8". Even after tweaking to fit in a 10", nearly 2" of the speaker bottom will get covered by the TV front lower panel. I've got my share of 10", 12" and even 15" single ended amps, so I kinda like having a few 8" versions around. |
#577 (permalink) |
I just gave it the ole college try. My order (back-order) would not process. BTW, I think whether you call MF or Music 123, you get the same switchboard. Total conjecture, but I think somebody high up at MF/123 decided it would be cool to pull these out of the supply chain, and use them as bait at some point in the future when other sales have flagged. Hey, if you can I can buy something and wait for the price to go up, why can't they? And so begins the urban myth of the 'missing 200'.
Bubban0v |
#579 (permalink) |
The blues ain't about theory, they's about therapy. |
#581 (permalink) |
So i've been lurking around this thread and poking around and playing with my GA 5. A couple of questions have arisen:
1. i know it was mentioned somewhere but there is a resistor between the pin and the wire on one of my tubes that has kept me hesitant from doing the NFB mod. The wire runs under the board from the volume pot and comes up through a drilled hole and there's a resistor between it and the pin. What is this resistor doing, what purpose does it serve, and more importantly can i still do the NFB? 2. I clipped the 1st stage 25uf cap and i plan to add a switch to allow me to bring back the nasty should i want it. 3. I jumpered the 1m resistor and 22pf cap tone stack and indeed the tone was beefier but i would also like to put this on a switch. I was actually wondering if it would be possible to have this on a pot so i could adjust how hefty the tone gets. Even with my tele its a bit too thick for my taste, at least with the stock speaker so a pot would be an ideal situation, if i could fit it. if not, then a switch would do just fine. 4. I have not added a standby switch, but I was wondering if it's necessary to purchase the switch that rob used or whether I could just use a normal on/off/on toggle. 5. Also, the grounding on the volume pot. I understand what I need to clip, but where would i run the wire to? 6. Thanks again for the amazing help this thread has been not only in tipping me off to this lovely amp but in giving me a guide to opening it up and messing with it.
Don't you dare tell me "you get what you pay for." |
