#441 (permalink) | |
Those are returns - I just knew that was gonna happen. |
#442 (permalink) | |
Also from memory the GA-5 has no 1M resistor from the input to ground. That was an error in the early Gibson schematics that got carried forward. |
#443 (permalink) | |
#444 (permalink) |
So on balance if I'm going to play my little Champion 600 for an hour, then go eat dinner and watch TV for a couple hours and play for another 45 minutes before bed should I shut it down or leave it humming?
Lazarus, Lazarus, How did it feel When you left this mortal world |
#445 (permalink) | |
So for harp players, a 4.7 meg resistor should be installed from the input to ground in vintage GA5s and in these new ones. For guitar, the input should be left as is. |
#446 (permalink) |
Hey folks :)
I hate to bring this awesome discussion back to elementary level (but I am a first grade teacher!) Anyway, I've gotten all the goodies I need to do the 3 original electrical mods you talked about, but now I'm balking. Chalk it up to inexperience. Could you break those 3 down fer me? What effect can I expect for each one? The lifted cap The jumpered resistor (1m + 22pf cap) The NFB Again, sorry to be so elementary! I am in love with my amp as is, and now I realize I may be getting swept away with results I'm not even sure of! Duh ;) droo |
#447 (permalink) | |
There is no way to fully describe what the trinity circuit mods will sound like for you - lots also depends on the kinda guitars/pickups you plug in, and what and how you play. The trio of circuit mods will remove that shrill boxy tone, allow for a fuller 'n' fatter tone, greatly reduce hum ... this basically somewhat lessens the raunchy, overly trebly "tweed tone" to a more manageable level. Just do all three at the same time, they compliment each other and they are way too easy to accomplish, OR to undo ... The lifted cap - cut the jumper, as shown The jumpered resistor (1m + 22pf cap) - solder a wire across those turret terminals, as shown The NFB - add a 47k resistor from the yellow wire on the RCA jack to pin 8 of the 12AX7 socket, as shown ![]() |
#448 (permalink) |
Rob, I'm waiting on you to post sound clips of your "modded" vs "unmodded" GA-5's. Since you've already done the mods (and like them) and have 2 amps, you're the logical choice to help some of us decide if we want to follow suit.
I'm Makin Progress |
#449 (permalink) | |
#450 (permalink) | |
Remember, the guitar tone path = brain, fingers, pickups, amalgam of the guitar, FX (if any), amp (circuit, tubes, speaker, etc). I can't say this any other way - the trinity circuit mods are so easy and cheap to accomplish AND UNDO that you should just do them and see for yerself. |
#451 (permalink) |
Thanks again Rob :) That last drawing is great!
I read this over on the FDP, "They're back!!!!!!! Just got off the phone with Gibson, and news is MF has bought out all of the entire GA5 directly from Gibson. No other online vendors will have these in stock as confirmed directly by Gibson." Interesting~droo |
#452 (permalink) | |
With all of the circuit changes, layout and other design differences, etc. between the vintage GA5 and this new one, the likelihood that the lack of a grid return resistor could be an accidental omission, carried over from the 50s to this new design, is less than infinitesimal. I'm certain that Gibson knew about effects pedals and tuners when they designed this new model in 2002 or whenever it was. |
#453 (permalink) |
[quote=specialty guitars;1150915]Yours is a unique one for sure. I can't imagine lifting that 25uF cap would make it sound "spotty and gargley", when all it does is reduce gain. NFB can be a tricky issue. I do wonder if the .1uF caps made it unstable. Yours is the only one that's had those problems (that we know of), and it's the only one with different value coupling caps. Amp circuits are kind of a "balancing act".
I thought about this and decided to try some other value NFB resistor. First I used a 100k , because the squeal was so intense, I figured the 47k must be way off if what you told me is the case. There was still squeal, but not so immediate or scary sounding. Next I used a 1 meg resistor (overkill?) to just determine if anything stopped the squeal. No squeal, but no noticable difference in the amps sound. So now I think I will hook up a pot and see if I can dial in something. To your ears, just how does the NFB change the tone or sound of the amp, what should I be looking for?
Blaaaa blaaaaa, waaaaa waaaaa, razzle dazzle, do dah, zzzzzzzzzz. |
#454 (permalink) | |
#455 (permalink) |
Carling off/standby/on added.
I pulled the GA-5 2-way power switch and removed the brown wire that goes to the IEC socket and the twisted pair of black and black/white wires from the PT. I moved those two wires over to the Carling switch (see diagram below). I removed the short white jumper between the rectifier diodes and the first filter cap, replaced that with a twisted pair of 18 gauge stranded wires (red and green). I connected the diode/filter wires to the Carling switch (see diagram below). I installed the Carling switch so that the end without lugs faces up (flipped the switch around as it looks in the diagram below) - and bundled all the loose wires together with mini tie wraps. The switch works flawlessly. ![]() ![]() ![]() |
#458 (permalink) | |
I can't say for sure without the amp in front of me, but my guess is that the .1uF cap installed between the second gain stage and the grid of the EL84 is causing the problem. Until you get your amp under control, there is no point experimenting with NFB. NFB smooths and evens out the frequency response. Early amps didn't have it at all. Tweeds acquired it, and blackface amps have more of it. Less, or no NFB (high value resistor or none at all) makes the amp sound "raw". More NFB (lower value resistor) makes the amp sound more refined, with a more even response. A common NFB resistor value for tweeds is 56K (some NFB). A common value for blackface amps is 820 ohms (a lot of NFB). |
#459 (permalink) |
#460 (permalink) |
Ok so now that were talking about harmonicas, how would a harp player with a real Green Bullet get more headroom or "pre squeel" action out of a GA-5?
Even out on the end of a 25' cord, I cant even hit 12:00 without drilling out some ears! |
#461 (permalink) | |
Have you done any of the mods to it that are discussed on this thread? |
#462 (permalink) | |
I've only done the 10' HD computer cable mod which I thoroughly recommend if you can find one. |
