#401 (permalink) | |
If I'm not mistaken, you said you had it on pin 7 in a previous post. Pin 8 (the correct pin) should cause no problems. The horrible squeal may be from using a mic with no input resistor. |
#402 (permalink) |
No actually I had it on pin 8 and it sqealed without anything in the input. It began to squeal as soon as the amp warmed up. I did ask about what looked like a resistor going into pin 7 on the pic you posted of the NFB mod. Right now the 22pf ,1 megbypass along with the .1 caps and the amp is sounding pretty sweet. I just finished building a 5F1 tweed clone and they are both a lot alike. I think the 5F1 is a tad better for harp, A little more grit, or honk. The GA-5 has got the juice. Using them with a DD-3 delay and the sound is real full for both amps.
Blaaaa blaaaaa, waaaaa waaaaa, razzle dazzle, do dah, zzzzzzzzzz. |
#403 (permalink) |
Earlier in this thread, someone had suggested that these amplifiers were imported.
I asked Gibson and have been told by them, in an e-mail, that these amplifiers were made in North Carolina. Mojotone is in North Carolina. Maybe that's why they have Mojotone components. I have even heard it said, in this thread, I believe and on other wbsites, that Mojotone built these amplifiers for Gibson.
Don |
#404 (permalink) | |
Save The Hymnals! |
#407 (permalink) | |
If you bought the parts individually and assembled it yourself: $300 - if you are very lucky. Chassis - 50 Trannys - 50 Speaker 30 Board resisters caps 25 that's 155 find a cabinet for 145 and you are in business . . . . Or are my numbers above way off? edit to note that RobDi beat me to it - and confirms that my guess is not as crazy as I thought. and to fix math - again |
#408 (permalink) |
Some components are definitely imported.
The Weber Signature speaker, for instance. I'm pretty sure it's imported. The input jacks were made in the UK. Eastern European tubes, etc. They used to come with US made Sprague filter caps. Not anymore. Have you priced Sprague Atoms lately? They're not worth what they get for them.
Don |
#409 (permalink) |
Mojotone gets over $500 for a tweed Champ kit. Weber, over $400.
Original '50s GA-5 amps can be had for less than $300, though. In any case, these amps were a good deal.
Don |
#410 (permalink) | |
Save The Hymnals! |
#411 (permalink) | |
#413 (permalink) |
Get a load of this, MF has abandoned the six digit code that matches this product. That leads me to believe that when a new version arrives, it'll be a Mark II or whatever. And anyone's guess as to price.
Kinda mind boggling to ask for $ 699 and not bother to put a US source speaker in the amp. I guess people's awareness on this subject has changed a lot in the last 2 years.
Bubban0v |
#414 (permalink) |
My Mesa/Boogie cost twice that and has a Celestion speaker that was made in China. Very Few speakers are made here and when they are, they're too expensive to put in $699 amps.
Don |
#415 (permalink) | |
I removed the resistor, and the amp is louder (as expected) and a bit brighter, but still stable. |
#416 (permalink) | |
So I can try it without it?
Don |
#417 (permalink) |
After playing my amp a while today, I decided that I like it better stock, so I reverted all the mods. I was never able to get that NFB resistor to function properly, The 25uf cap "leglift" just made the amp sound spotty and gargley, so now everything is stock except I left in the .1 coupling caps, I am really likeing the amp again. I sort of ABed it with my new 5F1 and they both are pretty sweet. I must say that I believe the 5F1 is a little richer sounding though. This is a great thread with some good ideas and timely responses.
#418 (permalink) | |
It's very slightly brighter and more open.
Don |
#420 (permalink) |
"Sort of", being a lazy way of saying aA/B'd. Sorry for the laxity. I ran them side by side , same mic, same setting, same song, same player. What can I say? To my ears, the 5F1 is a bit richer and has more body. The GA-5 has more muscle and volume, but not that suble little soul that is produced by a 6V6. The El84 is in my opinion a more volatile, dangerous, sound. I also used the line out in my 5F1 and ran them both together. Very cool. Mars and Venus holding hands.
