So is it the OT or the Circuit?
Folks claim that a Fender amp can take a mismatch on the OT. Like if you have a 8 ohm tranny you can hook up an other cab for a 4 ohm load and be safe ect. So if that is so is it the OT they used or the circuit being able to handle it? Just wondering as my Clone has a 4 ohm tranny which is fine for running a 2x12 cab at 4 0hms but it seems like 4 ohm speakers are tough to find or expensive If I had one I would run it and I am afraid to run an 8 ohm by its self and maybe blow up the tranny. The Tranny is a Stancor Tranny. Just wondering as I have a two 8 ohm cabs running in parralel for 4 ohms so I am safe running as is. I was wondering if running a 8 single speaker would hurt it. I suspect it would cut down on the volume though which I do not want so I do not really plan on doing it. I was how ever curious as say I was playing and one speaker went if the mismatch would hurt the remaining speaker?
| Sponsored Links |
I do not know for sure but I think I remember that Marshall for instance is not as tolerant to a 1:2 OR 2:1 mismatch as a Fender. Marshalls have impedance choices on the amp, Fenders do not.
I always thought it strange that Fenders let you add another (extension) speaker in parallel that would cut the speaker load impedance in 1/2 and wondered if the tranny wasnt designed to have some where inbetween the single speaker load and the dual speaker load on the other hand, isnt it OK to disconnect one speaker on a twin, or is it? |
When you halve or double the impedance that is reflected all the way back into the amp. The reason you can do it is older Fender amps work their tubes pretty lightly. Marshalls tend to work them a lot harder so impedance mismatches are a little more likely to cause issues.
If you have a clone specced like an old Fender then you should be OK as long as your tubes are biased up right. You have to realise you are using the amp harder so a slighlty higher rate of wear on tubes and some longterm components like the OT is likely - but it won't catastrophically destroy anything. If you drive it dimed with an mismatch and a overdrive in the front belting a really hot signal in you might have issues sooner rather than later.
My other Telecaster is a Thinline The Tele Bible, Ch 1, v 10 Love thy Telecaster, covet not thy neighbour's Strat! |
Thats good to know like I said I was just curious as I plan to keep the ohm rateing the same with no mismatch to be on the safe side. While a 4 ohm OT is kinda a pain as 4 ohm speakers are hard to find or expensive when you do find them running a 2x cab for a 4 ohm load is not that big of a deal.
The Fender OTs apparently are over-spec'd to the point where the mismatch is not a big deal (other than a bit of power loss). Other OTs may or may not be as tolerant of a mismatch.
You can go up but not down
Hello,
I saw you question and thought I would leave a comment. As a rule of thumb you can always go up in your load from the rated OT. For instance if you have a 4 ohm OT, your optimum/best performing load should be 4 ohm. If you present an 8 ohm load you will not hurt the transformer. Like you stated the sound power and tone will diminish because of the mismatch. Where you can hurt the OT is when your load drops below it's rating. Should you drop the load to say 2 ohm or say you put an 8 with a 4 ohm load, it drops to 3.2 something or there abouts, then you drop below the rating of the amp and you're in grey territory causing heat and a possible failure. Hope this helps. |
yes, I have the jensen RI C12N-4 ohm for my bassman head, good price at vintage speaker .com
works great for me not sure what is meant by the Chicago series. THe Jensen reissues (no series) are meant to replicate regular jensen speakers from the 60s. I know weber has a Chicago series. |
#12 (permalink) | |
"The Jensen Chicago Series is a new design speaker line from Jensen using a half century experience of classic guitar speaker design and modern effective manufacturing technology." - eg. here: http://www.tubeampdoctor.com/index.php?cPath=37_39_66 The one I was thinking about is called CH1270-4. |
http://www.vintagespeaker.com/search...ctmain=Speaker
these are the 12 inch Jensens vintage speaker.com |
