Fender Blues deville Blues
Hey people,
Can someone help me out there? I have a 4x10 deVille, and my problem is that the speakers kinda give a (farting sound) I play a 56 tele with all boss pedals, So I'm not sure if its the stock speakers or what. also, I changed tubes, 6L6s but that has not helped. any help ? thanks |
Sounds like a DeVille alright,, You might try Tungsol 5881's,, you'll need to rebias. The try Weber 10F150's,,, this will make you DeVille sound like a much better amp.
Keep your lamp Trimmed And Burnin Shannon, |
Not quite the same amp, but the same problem...
I recently put a Weber 12F150 into my Blues Deluxe RI.....all fartiness is now gone! Tightened up the bass considerably, actually it sounds so sweet now I've reconsidered my plans to build a 5F6A kit! I really cannot believe what this amp is now capable of on the bottom end, it really is impressive.
http://www.soundclick.com/darcyhoover |
#4 (permalink) | |
Dan
Teles are like Mr. Potato head |
I usually think of the 4x10 DeVille's,,, a couple Weber 12F150's will "fix" alot of the tone problems in these amp,,, how old is your amp?
#6 (permalink) | |
Dan
#7 (permalink) | |
I'm probably not very objective about it anymore,, I've seen so many of them that just never sound good. I should probably sit out at this point.
#8 (permalink) | |
My amp is a 4-10. Were there inherent problems with these speakers? I am sure the Webers are good speakers but at this point (and at that price) I would be inclined to get some of those Warehouse Guitar Speakers at 29 bucks a pop. Like you said, I might be throwing good money after bad anyway. I would try this If I knew for sure it was the speakers. Dan
Is this just a speaker issue, or is the problem common to other HR series amps with similar topology?
You wore a diamond watch, claimed it was from Uncle Joe; Well, I looked at the inscription, it said "Love from Daddy-O" |
#10 (permalink) | |
It's very simular the auto industry,, alot of people get into a car knowing that they will be making payments untill the car is worn out. They then go get into another car that they will have to make payments on untill it wears out. This is what keeps our economy moving,,, a constant cash flow. If your amp has no other problems at this point it may be worth putting Webers in it,, they will improve your tone greatly.
I was considering building a Bassman, one of the old hand-wired jobs, the 5F6A designates the circuit. There's quite a few kits available online and I thought it would be a fun project, but the speaker swap fixed all my problems.
I found that Torres Engineering offers a kit to rebuild the Deluxe's inards to a hand-wired Bassman circuit....may still give that a go in the future, as I do have a good speaker in it now! |
#16 (permalink) |
I dunno if you've the option, but an easy way to determine if your speakers are the problem is to plug the amp into a different speaker cab. You may have one around, or perhaps know someone that does. At least then you'd know what you were looking at without having spent any dosh. Just make sure the cab in question is of the correct resistance (impedance?), so you don't damage anything.
It would probably be best if you played the amp 'normal', set up to sound 'bad', so this would be obvious pretty quickly. If you were so inclined, you could also acquire a spare set of tubes, and do all the comparison at once. If you've got a "13" year old amp running original sovtek/GT/Fender branded 12AX7a & 6L6s, they might be due for an upgrade anyway. Good luck. --Almost forgot: They're not exactly the same, but a lot of info about the Deville applies as well as it does to the Hot Rod/Blues Deluxe, so give this stuff a read and see if any of it helps. http://studentweb.eku.edu/justin_holton/ |
