Old November 26th, 2003, 09:01 PM   #1 (permalink)
GuitarJonz's Avatar
Fender amp baffles
Anyone know what year fender changed from the screw-in speaker baffles to the non-removeable glued-in baffles?
Old November 26th, 2003, 09:16 PM   #2 (permalink)
zook's Avatar
Changed Baffles
I'm going to take an educated guess and say 1970. The 68 and 69 silverface amps were in the same style cabs as the BF amps. In 1970 they dumped the aluminum channel edgeing on the baffle and narrowed the Pro Reverbs cabinets.
Are you familiar with this page?
http://www.ampwares.com/ffg/index.html
Winnie Thomas
www.frd.cc/winamp
zook is offline   Reply With Quote
Old November 27th, 2003, 11:48 AM   #3 (permalink)
Ringo's Avatar
glued in baffles
It varies, some of the early SF amps still had floating baffleboards, I had a post 68 non master SF Twin that did.
But by mid 70's most if not all had the glued in baffle.
Tonally I don't personally think it makes much difference -but the older cabs seem to be ligher andof course its much easier to mod the amp with different speaker configurations etc with the seperate baffle.
Old November 27th, 2003, 01:35 PM   #4 (permalink)
tjalla's Avatar
Heads up Winnie!
Good ta see you on the board...
Your homepage in your signature is wrong tho
Dropping 6V6s into the Lizzie tomorrow, just got the Copper Cap from Ted Weber... fingers crossed.
Trev
tjalla is offline   Reply With Quote
Old November 27th, 2003, 08:57 PM   #5 (permalink)
zook's Avatar
Re: Heads up Winnie!
Trev
Trevor,
Rob gave me the heads up too. I think It's correct now.
Let me know how the copper cap works for dropping the voltage. The fellow that bought the one oin Rob's cabinet is interested in the possibility too.
I've been using a smaller PT and havomng very good results. It can take both 6V6 and 6L6 andis still plenty loud.
My Blue Lizzie is set up that way. It's the one I got back from Singapore because your current and the reverb circuit were incompatible. It works fine here. I've been using it for a long time.
Winnie
www.rfd.cc/winamp
I have noticed that happy people are often evaluating themselves and unhappy people are always evaluating others. -William Glasser
Old November 28th, 2003, 12:00 AM   #6 (permalink)
da dougster's Avatar
With the Twin Reverb's it was '72 when you first see the CTS/Utah/whatever speakers with JBL style offset speaker mounting holes. Also the same time of the 100Watt/ Master Volume change.....
"Somebody set up us the bomb!!"
da dougster is offline   Reply With Quote
