Old story (sorry) Pro Jr. noise...
Picked up a Jr. rather cheap with the intention of running it through a 2x10 vox cab. Surpirse!! The strong ringing noise isn't limited to the Weber 10F100 speaker in the Jr - when I plug it into another cab, the noise carries on.
I know there are countles threads on how to achieve the ultimate Jr. tone. I just want to get a noise-free sound of this litle demon. What's the quick fix? Thanks johnnie |
| Sponsored Links |
Unfortunately...
No fix that I know of for small lightweight combos... it's the EL84 tubes. I love the tone of amps with these tubes, and my primary gigger is a 1x12 EL84 based amp... but in my experience when EL84's are used in small lightweight combos you get sleigh bells with your guitar tone... the speaker shakes the cabinet. It's a tradeoff for portability. I'm used to it so it doesn't really bother me to much as live at a gig the "jingling" doesn't get amplified. Easiest fix I know of if is to use them in a head... seperate the tubes from the speaker. Or use a HEAVY duty cabinet. You can try tightening stuff down(ie. every screw in sight) or maybe using foam etc. where the chassis mounts to serve as a shock absorber... hmmm may have to try that myself.
re: EL84 tinkle bells
If yer using the PJr. as a head only (not its using its speaker at all) that should take care of the tinkles - if not, I'd suspect one or more of the following ...
* the PJr. is too close to the external speaker cab and is picking up its vibes * the PJr. combo cab should be placed on a thick, dense foam pad to isolate external vibrations * like JohnE sez, tighten down everything in the PJr. chassis and cab Good luck - EL84's have great tone ... and unfortunately that darned tinkle too. |
#5 (permalink) | |
#7 (permalink) | ||
8) |
Pro Junior
I retubed my Jr. with JJ's and it made a huge difference. Really woke up the amp.
I also put in a Jensen P10R which is better than stock but I would rethink it if I could do over again. Someone needs to design a point to point amp based on the Jr. Instant winner! I've pretty much decided on getting a Celestion Greenback for my Champ 12. Anyone have any experience with this speaker? It's described as having a woody, warm tone. Of course I would love to get the Celestion Blue but too many $'s. Thanks |
#10 (permalink) | |
After I tightened everything ( and I do mean everything) up, put in new tubes and removed the retainers, the rattle stopped. I fully expect some part of it to return as the tubes get worn in however.
I also found that some of the rattle was coming from my stereo set up and moving the amp away from there helped too ( it was sitting directly in front, about 10-12 inches away). Quote:
"Somebody set up us the bomb!!" |
#12 (permalink) | |
