#21 (permalink) | |
#22 (permalink) | |
http://www.tube-town.net/ttstore/pro...W---4-Ohm.html |
#23 (permalink) | |
Boys and their toys....
#24 (permalink) |
It took me a day to get used to it. It's not at all clear and bright like the old vibro-champs. Now I like it. It's not too loud or distorted-The just right. Doesn't disturb the people next door. The tubes were poor had to replace them in 6 months.
ANY OLD FENDER ROCK-A-DAY GUITAR |
#25 (permalink) |
Same here....different than my Vibro Champ....not better, not worse, just different. Took me a little time to get used to it, but now I really like it. I changed the tubes out a week or two after I picked it up last June, and have considered actually eBaying my VC to buy a Swart....
#26 (permalink) |
Okay - I just tried to get the back off this thing and it seems like it's glued on! Unscrewed what look to be the four mounting screws on the back - and it's not budging. Feels like it's gonna break before it comes off......anyone taken this thing off and have some tips they want to share?
www.thegearspy.com |
#29 (permalink) |
Thanks - did manage to get it off - although it was creaking like it was going to snap in two before it gave way.
#32 (permalink) | |
#33 (permalink) |
When Fender says they've upped the gain in the new Champ 600 versus the classic one, how much are they talking about. Is the low-gain input on the new one somewhere in the ballpark of the original?
I seem to recall seeing somewhere that the low-gain input on the new Champ produces a voltage gain of around 130 or so. Anyone know how that compares to a vintage Champ?
ON HIATUS |
#34 (permalink) | |
Q - What's the difference between a guitar and a tuna fish? A - You can tune a guitar but you can't tuna fish. |
#35 (permalink) | |
#36 (permalink) |
The original tubes had a slight difference.. Not too much tho. Kinda similar both in high and low gain channel. (But I hear it differs from champ to champ). But they´re ultra-cheap no name chinese tubes that have an extremely high failure rate.. So its advisable to switch them asap.
#37 (permalink) |
talmir,
When you changed to JJ pre- and power-amp tubes, was the pre-amp still of type 12AX7 (nominal gain 100) or some other type? Just this evening I swapped an old 12AT7WA/6201 (nominal gain 60) into my Champ 600 and the low input stays clean as a whistle even at 12 on the volume, although the whole combo sounds pretty boxy and compressed once I get to 11-12. The high input has to get up to 9 or a bit lower to start distorting and even then it's just a raw edge to the tone rather than a fizzy and/or splattery breakup as with the original Chinese 12AX7A. But once again it's getting unpleasantly boxy sounding before arriving at any obvious distortion. My initial impression is that the 12AT7 also shifted the EQ balance of the amp toward the treble a bit. But that's hard to judge without a real A/B comparison, which isn't practical when you have to root around in there and swap a vacuum tube in and out. It may just have tightened the bass up somewhat and that sounds like a brighter balance (such bass as there is with a 6" speaker anyway).
ON HIATUS |
#39 (permalink) |
I just bit the bullet and joined the club. Mine will be a modder's nightmare.
First get rid of that horrible, way too thick, grill cloth. That sucks up allot of the sound, just turn them around and listen to the back of these. Sweet! Then I'm gonna bypass the preset tone stack and change out the tubes. Maybe some orange drop caps and carbon comp resistors.
Play'n tele till I drop! *************** Bryan Hibler |
#40 (permalink) | |
