Old November 23rd, 2003, 01:24 PM   #1 (permalink)
JohnS's Avatar
Weber Copper Cap
Who here is using a Weber Copper Cap? Does it sound / act like a tube rectifier? Is it a "sounds like a strong testing Mullard?" Any problems? Thanks.
JohnS is offline   Reply With Quote
Old November 23rd, 2003, 01:36 PM   #2 (permalink)
Mitch Roberts's Avatar
Copper C ap
I think you'll find a broad consensus, among most techs and players, that the copper cap lives up to its billing. I have two now, and they sound great. What I REALLY like is that they make the amp run way cooler. I think it's due to a combination of not drawing the 5v for the rectifier tube heater, as well as the missing heat coming off the rectifier tube. For me, they have made tube rectifiers obsolete.
I think, therefore I jam.
Mitch Roberts is offline   Reply With Quote
Old November 23rd, 2003, 01:58 PM   #3 (permalink)
Rob DiStefano's Avatar
I can only echo what Mitch just posted - Copper Caps are the way to go. I read that Ted's coming working on a CC that'll allow for adjusting the B+ volatge which can be good for experimenting in cathode biased amps.
Old November 23rd, 2003, 02:24 PM   #4 (permalink)
Weber Copper Cap Rectifiers
I recently had a chance to see, hear, and sit in with Anson Funderburgh and thought his MAZ 38 (Yes, I know it's an Invasion. I had one before too but now have a Sr.) had better bottom end than mine and maybe a little more headroom. I asked Mike Zaite (Dr.Z) about this and he said he had recently installed a Weber Copper Cap Rectifier in Anson's MAZ 38 and recommended I try the same. I did and IT did just what Mike said it would do...better and tighter bottom end, more headroom. VERY noticeable improvement. I'm sold. 8)
jumpnblues
"Heaven St." (Original Blues Instrumental):
http://www.box.net/shared/static/z96atf0zn2.mp3
http://www.myspace.com/drbluezz
jumpnblues is offline   Reply With Quote
Old November 23rd, 2003, 10:02 PM   #5 (permalink)
Ben Harmless's Avatar
Are the CCs a plug-in unit designed to fit in the recto socket, or are they something else completely? I ask because I'm curious about using one on an amp that already has a solid-state rectifier. Would I essentially be modding for a tube rectifier, and then switching to solid-state, or is it less drastic than that?
- B. Simpson
Old November 23rd, 2003, 10:13 PM   #6 (permalink)
Read up about Copper Caps at the Weber website - Weber Copper Caps
Old November 23rd, 2003, 11:12 PM   #7 (permalink)
Glen W's Avatar
I put a WZ34 in my Allen Old Flame. I does everything a real glass GZ34 does, except light up. It also doesn't draw any current on the 5V PT tap, so the PT runs cooler. Any new recto "tubes" I buy will be Copper Caps.
Kinda wish they lit up though.... Ted?
Glen W is offline   Reply With Quote
Old November 23rd, 2003, 11:46 PM   #8 (permalink)
DavidP's Avatar
Ditto!!
I would not waste $$ on NOS rectifiers--have tried both the GZ34 and 5U4 versions in both VOX and Fender amps and they are great!!
DavidP is offline   Reply With Quote
Old November 24th, 2003, 02:10 PM   #9 (permalink)
Re: Weber Copper Cap
They work great. WZ34 (GZ34/5AR4 sub) does not sound like a Mullard. WZ68 may sound more like "a strong Mullard 5AR4."
WrapAround is offline   Reply With Quote
Old November 24th, 2003, 02:26 PM   #10 (permalink)
eryque's Avatar
Ben, it's solid state but behaves mostly like a tube and plugs into a normal tube socket. So if your amp requires any re-wiring for a tube rectifier, you'll have to rewire to use a copper cap.
I've got one in my Pro Reverb and it sounds great. Eventually one will go in the Princeton as well.
