#41 (permalink) |
A qualified yes. It still depends on a number of different things - speakers, preamp configs etc. But two Deluxe Reverbs played together should be roughly as loud as say a Pro Reverb - both scenarios have 2 x 12" speakers, around 40 watts. The second reverb tank in the Deluxe would make a difference by introducing some 'fullness'.
My other Telecaster is a Thinline The Tele Bible, Ch 1, v 10 Love thy Telecaster, covet not thy neighbour's Strat! |
| Sponsored Links |
#42 (permalink) | |
#43 (permalink) | |
Moderator
Remember, "50 watts" is a power measurement, not a volume measurement (that would be in decibels). It's like horsepower in an engine, and the speakers are like the transmission and drivetrain. A tractor-trailer with a big, powerful engine isn't as fast as a (relatively) small sports car, despite having much more horsepower! Same with amplifiers. Cheers, Tim
http://www.moodswingers.org |
#44 (permalink) | |
I obviously knew that a more efficient speaker is louder than one less efficient, but I was always under the impression that other things being equal, a 2x12 wasn't louder than a 1x12 with the same amp but just somehow had a different (smoother, more presence, better dispersed?) presentation from the stage. Theory being, I suppose, that the available power hadn't changed and was just didvided between two speakers instead of going to one. I guess this would assume the two cabs were as similar in design as possible. Good to know.
You wore a diamond watch, claimed it was from Uncle Joe; Well, I looked at the inscription, it said "Love from Daddy-O" |
#45 (permalink) | |
Secondly, a doubling in power output represents a 3dB increase. So by running 2 DRs you'd be putting a notional 44W into 2 12" speakers, which might sound a little louder, but not by a lot, and probably a bit fuller. On the other hand, other things being equal, if you're splitting the output from your guitar between two amps, each one is only going to be getting a reduced signal, so each pre-amp will have less input to amplify. Experience tells me that, especially if you put one amp on the floor and stand the other on top of it, the sound will almost certainly be fuller with more low-end, but not necessarily any louder. BUT if you then attenuate the bass to compensate you should be able to advance the volume controls further before running out of clean headroom, or for the same amount of breakup.
Proud to be The Man From Uncool. |
