Old January 16th, 2008, 05:22 AM   #1 (permalink)
ibobunot's Avatar
Hohner Hoodoo Box 5W Tube Amp
Hand-wired 5W Class A amp designed specifically for harmonica
EL84 power tube
1 -12 AX3 preamp tube
1 - 12 AU7 preamp tube
Celestion Super 8 - 8" speaker
Spring reverb.....
Gain, Tone, Volume, and Reverb knobs
Roadworthy cabinet covered in Tolex
Distinctive retro cosmetics
15-1/2"W x 13-1/2"H x 8"D
19 lbs.
ibobunot is offline   Reply With Quote
Old January 16th, 2008, 09:32 AM   #2 (permalink)
Tele Fan's Avatar
Nice!
Life is better when you just make it up as you go along.
Tele Fan is offline   Reply With Quote
Old January 16th, 2008, 09:38 AM   #3 (permalink)
Hoodster's Avatar
$279 @ MF:
"The Hoodoo Box is a 5-watt, Class-A, hand-wired tube amp combo designed especially for harmonica players. Built from the ground up to produce the fat, distorted tones that are the cornerstone of the electric blues harp sound, it is equipped with a single EL84 power tube and a 12 AX7 plus 12 AU7 tube complement in the preamp stage. Its classic spring reverb will add drama and air to your performances while the Celestion Super 8 8" speaker is especially suited to reproduce the entire range of harp tones. The XLR direct output can be used for recording or as a send to the front of house PA.
The Tone control helps you dial in the right sound with a range that goes from Dark to Bright to Scooped, the latter setting giving you a flat-out, heavily distorted sound. The Hoodoo Box will bring out the best in your harp technique as well as your mics.
The roadworthy Hoodoo Box cabinet features classic styling with rugged Tolex covering, white piping and special Hohner grille cosmetics.
From growls and soulful wailing to dynamic virtuosity, the Hoodoo Box will bring these sounds and more to your harmonica playing."
Hoodster is offline   Reply With Quote
Old January 16th, 2008, 09:57 AM   #4 (permalink)
Tdot's Avatar
Hohner has had this site up for awhile. I've been waiting to see these things.
Old January 16th, 2008, 11:48 AM   #5 (permalink)
Big Tony's Avatar
Cute!
/ Tony
If Telecasters were outlawed, only Outlaws would play Telecasters. {8^)>
Big Tony is offline   Reply With Quote
Old August 28th, 2008, 02:00 PM   #6 (permalink)
GROOOOVED's Avatar
Anyone use one of these with a guitar yet?
GROOOOVED is offline   Reply With Quote
Old February 20th, 2009, 11:08 PM   #7 (permalink)
I am interested in this amp as well - for use with a guitar.
It seems like it is a cheap alternative to some other overpriced tube amps
z0z0 is offline   Reply With Quote
Old June 9th, 2009, 07:52 AM   #8 (permalink)
Anyone ever get one of these for guitar?
asatbender is offline   Reply With Quote
