Confused about Ohms and speakers
With regard to my new amps extension speaker jacks, there is one jack with a lever to select either 4 or 8 ohms. I have a epiphone Valve Junior Cabinet that reads 16 ohms on the back. Can I use that Epi cabinet as an extension speaker cab? If so, which do I select on the back of the new amp 4 or 8 ohms? It say the toal load must be 4 or 8 ohms so what load would the 8 ohm speaker in the amp and the 16 ohm speaker in the Epi cabinet put on it.
I'm hoping it will equal either 4 or 8. |
You should call the amp makers toll free number if possible to make sure you won't violate your amp warranty if you hook that cab to it. I'd get a cab of either 4 or 8 ohms to use with it myself.
Depends on how speakers are wired. You'll have an impedance mismatch with the 16ohm cabinet. It won't hurt the amp, but the output power of the amp will be decreased. With a 8ohm internal speaker and a 16ohm added in parallel, you'll have a 6ohm speaker load. I'd put the selector switch on the 4ohm selection. It's not good to run an amp below it's output impedance. The best bet would be to get another 8ohm extension speaker, then you'd have 4ohms with them all hooked up together.
Good luck.
Play'n tele till I drop! *************** Bryan Hibler |
An 8 and a 16 ohm speaker in parallell would give you 5,333 ohms in total, which should be just fine with the amp's impedance selector set to 4 ohms.
But just as Twangbanger sez, the best thing would be to get another 8 ohm speaker, since that would give you the 4 ohms which the amp "calls for". Good luck! |
Seymour Duncan has an Ohms Cal http://www.duncanamps.com/technical/impedance.html
This is one that I used http://colomar.com/Shavano/impedance_proc.php
tazzboy Guitar: 1982 Gibson Les Paul Standard AMP: 59 Bassman Reissue. EFFECTS: 2 Boss TR-2 Tremolo, Boss CE-2 Chorus, and Boss DM-3 Echo Delay. |
What amp do you have?
Is the Valve junior amp head unit designed for 16 ohms or it may have an output transformer with different load taps? If so, then that's why. Speakers come in all kinds of impedances. Champs have a 3.2ohm impedance and most 2 speaker fender amps are rated for 4ohm impedance. Just depends on the amp design specs. I noticed that the Epi extension cab only comes in a 16ohm version. Here's the calculation for speakers in parallel. ![]()
#9 (permalink) | |
So Marshall impedance selectors usually have 4, 8, 16 ohms settings. I'd say when you plug the extension in with your amp you are converting the 16 ohm tap off the output tranny to the alternate 4 or 8ohm setting. Then you have the option of a total 4 ohm load, which as the others point out covers an extension cab below 16 ohms; or 8 ohm which covers a 16 ohm cab plus the standard internal speaker. If your internal speaker is 16 ohms, then your total load is 8 with a 16 ohm extension cab. Marshall and PV also made single speaker 16 ohm cabs, and Vox used two 2 x 16 ohm cabs in their various AC30s for 8 ohms. It's just the British vs American standard of 16 ohm s vs 8 ohm speakers and the differing plethora of output impedances you get. At least they gave you 4 or 8 ohms, which covers most options adequately.
My other Telecaster is a Thinline The Tele Bible, Ch 1, v 10 Love thy Telecaster, covet not thy neighbour's Strat! |
Still not sure if I should hook up the VJ cab for fun or not. ANd which to select the 4, or 8 ohm switch on the back of the amp. Again, the amps speaker is 8 ohms and the VJ cab is 16 ohms.
#13 (permalink) | |
great info tazzyboy! no more questions...! thanks |
