Old December 30th, 2007, 05:05 AM   #1 (permalink)
Epiphone Valve Special - preamp distorsion any good?
Sorry for partly repeating a question I posed here in August.
I have an Epi VJ combo and I like its sound. Since I can't crank it to powerstage breakup at home, I wonder whether the Valve Special can provide good enough preamp distorsion at "home volume" to justify a switch.
I have read some comments about the VS stock speaker being no good and that it is very dark sounding. Is it darker sounding than the VJ with stock speaker?
I will of course try it before I buy, but I have to drive 120 km to do that, so would be grateful for any input.
Klas
...all the times I've had to play while people sat there drunk...
klast is offline   Reply With Quote
Old December 31st, 2007, 08:53 PM   #2 (permalink)
I've owned both of them, and the pre-amp distortion is not apt to please you on the the Valve Special. Try to find a used attenuator on E-bay, like a Weber Mass to use with the Valve Jr. and you'll likely be happier with the result. I was a lot happier with the attenuated sound of the Valve Jr. than with the Valve special. A tube screamer in front of the Valve Jr. can work nicely, as well: but it's still not output distortion.
fauxsuper is offline   Reply With Quote
Old January 1st, 2008, 05:13 AM   #3 (permalink)
Thanks, that was valuable to know. I have considered a Weber attenuator or an L pad, so that might be the way to go.
Right now I'm using a Zoom G2.1u in front and have finally managed to dial in some nice overdriven sounds. I also have tried a tube screamer (in an Ibanez U300).
Klas
vB code is On
Forums Directory
