Best 6V6 Tubes for SF Deluxe Reverb
Just scored a SFDR on eBay. She's going to the amp doc to get gone through and have at least the power tubes replaced (they're the original tubes from the amp, according to the seller!)
What 6V6's do you like? JJ? EH? I'm partial to the EH's that are in my DRRI, but I haven't compared them to JJs. Other brands? |
Unless you already know they're bad, why not wait to see if they need replacing. I picked up a '69 Deluxe Reverb earlier this year and me and the amp tech both agreed, at least right now, it didn't anything replaced. I can't imagine it sounding any better. But, to answer your question, if I were to change the power tubes, they would be NOS. No JJ's or EH's for me in my old
Fenders, thank you. YMMV
I'm Makin Progress |
yeah, don't write off the old ones. they very well could be better than most any modern replacement. if it is time for new ones... JJ's are good, BUT I'd really recommend old stock tubes. favorites include RCA's and Brimars. most of the USA and europe brands should get results that few modern manufacturers can manage.
'86 mij '62 Custom Tele ----> '08 Marsh 5F4 Super kit or 60's Silvertone guitars (Harmony-made) ----> '66 Princeton Reverb http://www.myspace.com/jswattsmusic |
This is going to be my main gigging amp. I don't want to wait until I'm in the middle of a set for the 30-year old tubes to fail and I'd like to preserve these original tubes if the day comes when I decide to sell it.
If I went with, say, some NOS RCA blackplates, how long do you think they might last with 4-6 hours per week of use at band volume? |
If this is your main gigging amp don't bother with NOS. While I agree most NOS tubes will sound better at home and in a recording situation the audience will never know live. Get a set of JJ's your wallet will thank you and they are robust enough to stand up to a ton of abuse. Plus I think they sound just as good as some of the NOS I've tried. Not the same as black plate RCAs but I think they hold up well against the Sylvania 6v6gta's that I've had in the past.
I've been pretty satisfied with JJ's...
in my SFDR which is my main club gigging amp so it gets constant use. I also really like these as an alternative to RCA NOS: http://www.kcanostubes.com/products/...tched-Pair.htm
barely in tune and teetering on the brink of oblivion... |
#9 (permalink) | |
Have the bias checked and adjusted if needed. Have the electrolytics checked for leakage and replaced if needed. If it ain't broke, don't fix it. MikeY |
#10 (permalink) | |
I have 1958 12AX7's in my PR. MikeY |
Moderator
Those original 30-year-old tubes are very likely RCAs, and if the amp didn't have a whole lotta hours on it, they're probably just about the best possible tubes for it! At least have your tech check them out, and probably fine-tune the bias.
Cheers, Tim
http://www.moodswingers.org |
#14 (permalink) | |
When the world comes to an end, the only things left surviving will be cockroaches and old tubes.
#18 (permalink) |
Tung-Sol's, but save those old tubes! Also be careful if your tech advises "mods" or very extensive restoration.
"I feel that it is healthier to look out at the world through a window than through a mirror. Otherwise, all you see is yourself and whatever is behind you." - Bill Withers |
#19 (permalink) |
i've used the new tung-sols back to back in the same amp with the new jj's and the tung-sols are warmer. in comparison the jj's sound 'sterile' and very 6l6ish. i'm using the tung-sols in an amp with 455v b+ voltage and they are holding up fine. i've also got a pair in a cathode biased amp operating at 110%rated max dissipation and they're holding up fine.
here's a review of current 6v6 tubes, where they note that the added 'bite' in the jj might be better in a bar situation where you have to cut through the mix, but that the tung-sol sounds more 'nos': http://thetubestore.com/6v6review.html |
