Old December 5th, 2007, 11:24 AM   #1 (permalink)
twangpunk's Avatar
Twin, Pro Reverb, or Princeton?
I'm looking into buying a nice little "Swiss Army" amp to cover all my needs. I play "rootsy" stuff but I'd describe not only raw Blues, and old Country as roots music but also Garage Rock(old and new) and early Punk Rock in much the same way. And to round things out I like to do zany, experimental stuff as well.
I play gigs at small clubs and usually mic my amp, and I want an amp that can play super-clean but breaks up and get's mean when cranked. The Twin is heavy, expensive and too loud in most cases so I'm leaning toward the Princeton Reverb but now the Pro Reverb has me interested.
I'm willing to entertain suggetions for Non-Fender amps but for now it'll have to be a Fender Tube Amp of some kind. Somewhere below $ 700 would be nice too!
"You just can't live in Texas if you don't have a lot of soul!" - Doug Sahm (Oh, that it were true...)
twangpunk is offline   Reply With Quote
Old December 5th, 2007, 11:44 AM   #2 (permalink)
Bill's Avatar
First off, I'm not much of a player and I only play around the house, but...
I have a Princeton Reverb and a later 70's, 70-watt Pro Reverb. The Pro can be very loud. You'd have to use pedals unless the club you are playing is very, very large. The Princeton would have to be miked I'd think any time you wanted clean, unless the club you were playing were very, very small--like a coffee shop.
One other option you might consider if you can try it is a Super Champ. Mine is louder than my Princeton but quieter than my Pro. It's super portable, too. But I'd suggest upgrading the speaker, I think it's the weak link. Another option would be a Deluxe Reverb. You could crank that in a club or mike it for clean.
WilliamBaeck.com
Bill is offline   Reply With Quote
Old December 5th, 2007, 11:56 AM   #3 (permalink)
Fender's line can be simplified based on increasing power
Champ - 5 watts from one 6V6 single-ended
Princeton Reverb - 12 watts from two 6V6s in push-pull
Deluxe Reverb or Vibroverb - 32 watts from two 6L6s in push-pull
Vibrolux Reverb - 40 watts from two 6L6s in push-pull
Twin Reverb - 85 watts from four 6L6s in push-pull
Many consider the Deluxe Reverb to be the workhorse for clubs, although the Princeton Reverb is favored as being lighter and easier to carry.
Many consider Twins to be obsolete because of their power, size and weight, however, this means that you can get a fantastic bargain on a used one, if you know what to look for.
PRNDL is offline   Reply With Quote
Old December 5th, 2007, 11:56 AM   #4 (permalink)
Chris Callahan's Avatar
I agree the pro can be too loud and too clean. I would go with the Princeton.
Chris
Chris Callahan is offline   Reply With Quote
Old December 5th, 2007, 12:00 PM   #5 (permalink)
Out of the amps mentioned so far, I agree with Bill that the Super Champ will fill the bill you are shooting for. The OEM speaker is useless, imo. IF you replace that with a good Alnico and learn to turn the knobs, you can do what you want with one.
Old December 5th, 2007, 12:12 PM   #6 (permalink)
Maggot's Avatar
I'd say that if you're playing rock & punk in clubs, a Princeton would sound too small - not that it wouldn't work, but with 1-10" and 12 watts you'd have to be making an aesthetic decision to be playing with a smaller sounding amp i.e. I'd go for the Pro, or ideally, a Vibrolux. If you're thinking small, I'd probably not go smaller than a Deluxe. The advantage of the Pro over the other mid-size Fenders is price, probably due to the bulk.
www.soundcloud.com/feierman
Maggot is offline   Reply With Quote
Old December 5th, 2007, 12:18 PM   #7 (permalink)
twangpunk's Avatar
Thanks for all the suggestions! I'm currently playing Americana/Texas Music/Honky-tonk stuff with a band that doesn't even have a drummer but I'd like something that could work with a drummer and louder stuff.
I love the idea of the cranked little amp pushing the tubes to distort instead of using pedals but most of the guys around here ( even the ones that aren't Gibson/Marshall "size kings") have larger cabinets, even some that aren't combos so I'm feeling a little inferior.
Lot's to consider.
Old December 5th, 2007, 01:49 PM   #8 (permalink)
blue metalflake's Avatar
Depends on what you really want. As you say the Twin is heavy and loud. The Pro is slightly lighter, not just so loud, but every bit as clean. I used a Pro for many years, in some big venues, and it just stays clean, way up.
I've no experience of a Princeton, but if you want something you can really drive, get something smaller than a Pro.
blue metalflake is offline   Reply With Quote
Old December 5th, 2007, 02:01 PM   #9 (permalink)
Paul in Colorado's Avatar
I don't know where this thought came from, but I think you'd be happier with a Vox, Matchless or Bad Cat amp. They'll give you some clean, but with a little more drive on tap. Go play every amp you can get you hands on and take you're time. You'll know it when you hear it.
Old December 5th, 2007, 02:14 PM   #10 (permalink)
kludge's Avatar
I've played with a particular drummer for years, mostly using my little 15 watt Trace-Elliot Velocette with a 10" speaker. A while back, he commented to me that he simply couldn't understand why so many other guitarists he plays with use really big amps, especially stacks! He said my tone was always great, and my volume was always just right... other guitarists were too loud, and with dull tone because they don't push their big amps hard enough.
To chime in with others here, I think a Deluxe would be PERFECT for you - a silverface Deluxe Reverb should fit your budget, or a new reissue. If you want a dirtier tone, look for a modern Tweed Deluxe clone... no reverb, but killer tone. Just-starting clone makers often have them in your price range, or maybe a used one from an established maker.
For touchstones, Richard Thompson has a classic Deluxe Reverb tone, and Neil Young has a classic Tweed Deluxe tone.
Oz: Well, other bands know more than three chords. Your professional bands can play up to six, sometimes seven completely different chords.
Devon: That's just, like, fruity jazz bands.
-from Buffy the Vampire Slayer
kludge is offline   Reply With Quote
Old December 5th, 2007, 02:23 PM   #11 (permalink)
Get a SFDR.
Flannel Pat is offline   Reply With Quote
Old December 5th, 2007, 04:04 PM   #12 (permalink)
bo
bo's Avatar
I've never used a Pro, but 70 watts is a lot. A Twin is A LOT of amp. I've used Twins, Deluxes and a nice SF Princeton at length for an "everything" sound (country, blues, punk, etc.). I would definitely consider a Deluxe. As mentioned, a SF one would be a very good choice IMHO.
bo is offline   Reply With Quote
Old December 5th, 2007, 04:30 PM   #13 (permalink)
An early 40-watt Pro REverb is a cool amp. Wit the tube rectifier and the small output transformer, it does things that a TR or the ultrarlinear 70-watt Pro REverb will never do....it compresses more and sings more readily. IT is more in the vein of a DR. The two of them will do the BF REverb amp clean like a TR but when pushed they go into distortion and compression sooner and more smoothly.
The 40 watt Pro REverb can still be a handful of volume for a small club. A Deluxe REverb is the next step down.
Old December 6th, 2007, 01:08 PM   #14 (permalink)
Paul G.'s Avatar
One correction and suggestion.
First--a Deluxe Reverb is 22W from two 6V6, not 32W and two 6L6.
Now, if you always mic your amp, and want a bit of drive I think the Pro Reverb and Twin Reverb are probably too much amp.
I think you'd be happier with a Deluxe Reverb or Princeton Reverb. Plenty of guts for gigging. they may not always fill every room, but you are reinforcing it through the PA. You will get reasonable stage volume and perfect tone.
SF Princeton Reverbs are around, but the prices are rising. SF Deluxe Reverbs are way expensive, but the RI is pretty nice and available used in your price range.
Also recommended--Used DrZ Carmen Ghia, Used or new Peavey Delta Blues.
P.
Listen to your mother
Paul G. is offline   Reply With Quote
Old December 6th, 2007, 01:14 PM   #15 (permalink)
Get the 40 watt pro. You can always dirty up an amp with a pedal in quiter situations but you can never find extra clean headroom. I have had Twins, Deluxes, and a Pro. In my opinion the Pro is the best of all worlds in Fender land.
Mike Dickerson is offline   Reply With Quote
Old December 6th, 2007, 01:17 PM   #16 (permalink)
hal
hal's Avatar
Go for the Pro..
If you can find the 40W version. I have had all of these amps. I still have the Deluxe(a 66--my first amp) and I wish I had hung onto my 68 Pro.
Wherever you go, there you are.
hal is offline   Reply With Quote
Old December 6th, 2007, 01:21 PM   #17 (permalink)
refin's Avatar
I used to run a Super Champ into a 1-12 cab with an EV speaker,and it flat cooked.
"For You,Lord,are good,and ready to forgive,and abundant in mercy to all those who call upon You."
Ps. 86:5
http://www.soundclick.com/bands/0/refin_music.htm
MASTER VOLUME? WHAT'S A MASTER VOLUME?
refin is offline   Reply With Quote
Old December 6th, 2007, 02:00 PM   #18 (permalink)
R.I.P.
trag-o-caster's Avatar
It's so good to see the old Pro's get some lovin'!
I'm MADLY in love with mine! I've read where folks have bashed them, due to their "wimpy" transformers, but that amp has a tone like no other. You are correct Wally - Twins won't do it, my 69 DR won't do it. They're all great, but they don't do the same things. I've long ago decided that my 73 Pro'verb with the 2 Celestion G12H-80's is the BEST sounding amplifier that I've ever played through in my life. I do use the Morley JD10 because of the Pro's volume, or occasionally the Weber MASS.
The weight is another issue though. I often wish that I could make my SFDR sound at least similar, but nope.
Special thanks to Tim Swartz for looking after these babies!
Timothy Jon Lamb
trag-o-caster is offline   Reply With Quote
Old December 6th, 2007, 03:07 PM   #19 (permalink)
I've been contemplating this same question. I have a late 60's SFDR that I bought along time ago and never used. I gigged with it last weekend and was blown away by how great it sounded. Since our amps are not mic'ed, I pushed it to the max the whole gig.
I see the posts about the Pro RV and Vibroluxe RV being the bigger 40 watt version. Do these sound like the Deluxe or do the difference in tubes/transformers alter that tone? I just want a bigger SFDR.
blkhrs7 is offline   Reply With Quote
Old December 6th, 2007, 03:12 PM   #20 (permalink)
What speaker is in the SFDR? Some of the late '60's OEM's are notoriously lo-efficiency. An Eminence LEgend GB128 will double that apparent volume if your speaker is lo-efficiency. I replaced some lo-efficiency OEM Oxfords in a BF Pro REverb and was blown away by the difference in volume.
