Old October 23rd, 2007, 05:41 PM   #1 (permalink)
halouis's Avatar
PA amp speaker question.
i have an old 70 watt Yamaha Powered mixer thats been lying around and I was gonna give it to my buddy ho could use it.
not sure what ohm speakers it needs. on the back it says under the 2 1/4" outputs:
1 and 2 :8--16ohm
1 or 2: 4--8ohm
~ Hal
halouis is offline   Reply With Quote
Old October 23rd, 2007, 06:40 PM   #2 (permalink)
Dacious's Avatar
It sounds like it is a mono desk with a minimum impedance of 4 ohms, which is pretty standard. There is some stuff that will take 2 ohm loads, but you're running very close to the wind running there - clipping/overheating/distortion in a PA and/or overloading is a minor short or intermittent fault away.
So what it's saying is if you use one speaker input only, the load should be 4 ohms or 8 ohms. If using both which are connected parallel, use 8 ohms speakers minimum for 4 ohms total.
Using higher ohmage speakers would be OK, but I bet the volume falls right out as 70 watts ain't much. You'd then risk overheating it by pushing volumes too far.
I'd recommend changing the electros in it - they go in these too, and the results are just as bad as a tube amp.
Old October 24th, 2007, 08:47 AM   #3 (permalink)
halouis's Avatar
thanks Dacious! that helped. yes its a mono deal.
~ Hal
