Are bass speakers and guitar speakers interchangeable?
I need to replace a bad speaker in a PV extension cab for bass. Are guitar and bass speakers essentially the same thing? Can someone make a suggestion? They are 10", 4 ohm speakers, 2 of 'em.
Thanks, Adam
Why yes, I do have a liberal arts degree...do you want fries with that? |
I have heard that bass speakers are very inefficient...
To get frequency response down to the lowest frequencies, there is some trade-off for power and headroom. So a speaker with a cutoff down in the "low B" range will typically be less efficient than it's couterpart for guitar. And of course it takes a ton of power to amplify bass for this reason. So a bass speaker would probably be great for guitar but not vice versa. -Dan |
Bass speakers are for bass
The waveform of a low bass note is very big physically. A bass speaker has a longer excursion (throw) than a guitar speaker to reproduce the notes. Typically a bass cone travel is about 1/4" whereas a guitar speaker only moves 1/8' max. This is what kills a guitar speaker used for bass.
Dave at Avatar can get you good prices on Eminence bass speakers - or Celestion if they make them, though I haven't bothered to check.
You can probably also buy cheapish Peavey bass speakers from Musician's Friend.
