Pro Jr vs Classic 20
I'm looking for a small amp for rehearsing with, and have been thinking about the Pro Jr, the Classic 20, or the Crate Palomino 16 (or 1512). They all do a lot of the same things, and people have good opinions of all. My Q is, can the Pr or Classic take a 12" speaker? I really don't like the little boxy sounds 10"ers get!
Want my guitar to sound like BBQ tastes! check out the band at http://www.myspace.com/brightredtie |
There's an aftermarket upgrade for the PJ (called the pro senior) that is a new tweed cab for the chassis that takes a 12". Unfortunately, the cab (without speaker) is $275 (more than I paid for PJ). By the time you add a decent 12", you're just about in DRRI land - which kind of kills the value proposition for a PJ.
A 12" won't fit in the PJ's stock cab, so going with an external cab is probably the cheapest, fastest way to get to a 12".
Elwood: Good evening ladies and gentlemen, we're sure glad to be here in Cocomo tonight. We're the Good Ole' Blues Brothers Boys Band from Chicago. I sure hope you like our show. I'm Elwood, this here's my brother Jake. |
I'd do the cab thing as well.
It makes the most sense without having to go w/a special enclosure for any of those amps. And for those rare times when the extra portability and light weight is an issue, you can just grab one of those little suckers and go. Anything over 4-5 watts can drive a 12".
Have you played your favorite guitar with a Pro Junior? You should try it. For smaller amps, I have a Pro Junior, 70's Silverface Champ and an Epi Valve Junior head with a 1-12 Lopo Closed back cab.
The Pro Junior is my favorite. It's not boxy. Champs fans will call it sacrilege but if I could only keep one of my lower power amps, the Champ and Epi would go out the door.
JLG Carry On |
The little Peavey sounds alot bigger than it looks. It sounds good with the stock speaker, I upgraded mine with a Weber Silver 10 and it's awesome- not boxy AT ALL. It's one of my amps I doubt I'll ever sell.
"I've got callouses, from all those nights, spent playin' a Telecaster, 'till my fingers bled Bud Light" - Travis Tritt |
I'd say Classic 20 myself, but that's just because it is my absolute fave of all of the Peavey Classics.
Not much clean headroom, but when it starts to break up it just sounds beautiful. It also doesn't have any garbage in the circuit like most of the other models do. And a small fact that most folks don't know - the C20 has DC fils on the preamp tubes. This was back when it was almost unheard of with a little amp like this. Yeah - there are plenty of great sounding 10s out there (I love a 2X10 setup). The only drawback is that most of these mini amps have tiny cabs, and even a good 10 will typically sound less awesome than if put in a bigger box - that's why I recommend a speaker cab.
Thanks for the tips, guys. I went out today and - of course - couldn't find either the PJ or the C20. I did play and like both the Blues Jr and the Crate Palomino 16 though, each in its own way.
#9 (permalink) | |
what does this mean as far as tone goes? DAVE: You won't find a C20 except used, it was discontinued awhile ago. They're going for about $275 on ebay these days. My favorite of the Classic series as well.
It doesn't really do anything for tone, but it does help with noise (especially as the amp is cranked). It reduces noise to have DC filaments on the most sensitive part of the circuit - the preamp. AC hums... giving the 6.3 volts required to the tubes heater filament as DC instead of AC means less noise/hum into the preamp circuit. |
Thanks, JC. learnin' a little bit at a time about this amp stuff... I WILL build one someday...
If you've had a few noisy tube amps, DC filaments can be a wonderful thing.
Not really an issue on an amp with a very clean tone (very low preamp gain design), or one with really good lead dress (how the wires are laid out inside the amp). Being that the C20 is both mass produced and PC board construction, the DC filaments are great. I believe that Epi had to modify the Valve Jr. for the same thing, because of excessive hum. I like to think that the DC fils are just another indicator of smart design, and that Peavey was way ahead of the competition with their small tube amp design, over a decade ago! Why they don't re-release the C20 is beyond me, with all the rage being these little 18 watt wonders. I guess they hope to achieve something similar with the Windsor Studio.
I have had no experience of a small fender, but have been very happy with my Peavey 'Classic 20'.
The headroom an definition improved even more when I fitted a 10" Jensen ceramic speaker and differently voiced EL84s from 'Watford Valves' here in the U.K. It looks even better if you unscrew the 'Peavey' logo from the front - and just have that lovely tweed speaker grille. The only minor downside, is that the valves are fully exposed at the rear, so be very careful when putting the plug and mains lead back after playing - and check they are securely seated before switching on e.t.c F.F.
" The blues is the truth : happy or sad - just the truth " |
#14 (permalink) |
I have an older Tweed PJ. It sounds boxy and harsh. Not an amp I can love for guitar. In fact I will never use it for guitar again. I'll keep it for harp playing. I wouldn't spend any more money on this amp. Like someone said above, move into a DRRI before you do that.
"If you don't like the Blues, you got to have a Hole in your Soul." Luther Allison JOE |
#16 (permalink) | |
The problem with many of the modern small tube amps is that there is simply too much circuitry. This is why most will favor the Champ. I think that the Peavey C20 is the best blend of the old and the new - a couple more modest gain stages, and a low-watt push pull design that still feels a little loose, and not boxy or boingy like the PJ and BJ.
