fundraiser
Old October 24th, 2003, 03:17 PM   #1 (permalink)
blondeonblonde's Avatar
Tweed Champ Mod Question
I recently bought a Tweed champ, and I was talking with a friend, who happens to be a very clever builder/tech- He was telling me about a mod to do to a Tweed champ that sounds incredible-
I think i have this right:
Find the Cathode bias resistor, and and bridge a 10 MFD electrolytic across it-
He says it makes the amp just scream...
I was wondering if you guys have ever heard of this mod, and what it does exactly?
I've always thought that Tweed Champs did not need any mods, but this one sounded pretty simple and non-destructive... Any thoughts????
blondeonblonde is offline   Reply With Quote
Old October 24th, 2003, 03:37 PM   #2 (permalink)
Tim Swartz's Avatar
There is already a 25uF cap there. Adding an additional 10uF cap would be pointless.
Old October 24th, 2003, 04:08 PM   #3 (permalink)
Screen resistor?
Tim, if you are still watching this thread, what are your thoughts on the necessity for putting in a 470 ohm/1 watt screen resistor on the 5D1, 5E1, and 5F1 Champs?
Old October 24th, 2003, 05:48 PM   #4 (permalink)
BrianF's Avatar
no...the 25 uF cap goes across the 1500 ohm
resistor to ground that is located at the junction of where the feedback resistor is connected...
It is covered in this site...
http://www.tone-lizard.com/lesson10.htm
go that link and then scroll down the page...right next to the picture of the Tweed Fender amp...
Old October 24th, 2003, 08:33 PM   #5 (permalink)
JDO
JDO's Avatar
Re: Tweed Champ Mod Question
if he's a knowledgable tech the only thing i think he could be talking about is the cathode bias resistor in the first gain stage. on the 5F1 schems it's not there but i've never actually heard of one that didn't have it. but he's right, if you're doesn't have it, it will make it scream. before they took it out, it was a 25/25. you could experiement with whatever value you wanted. just look at the board. all the way to the right is a resistor (either a 1k5 or an 820 - don't have the schem infront of me). if it has a cap in parallell with it, don't worry. if not, then put one in and see if you like it.
clean as a whistle
JDO is offline   Reply With Quote
Old October 24th, 2003, 08:42 PM   #6 (permalink)
Tim Swartz's Avatar
Not necessary with good (NOS) 6V6s. Any amp using current production 6V6s would be advised to bump of the screens (until they don't glow when you lean on 'em).
Old October 24th, 2003, 09:36 PM   #7 (permalink)
Jparris's Avatar
Man, Tweed Champs scream STOCK!!!
One of my favorite amps (5F1). Leave it as is, IMHO.
jparris
Richard Hell: "Musicians were being worshipped as idols and I thought that was pathetic and a lie. So I was undermining that -- wearing these beat up clothes & talking about real life, not romantic love songs and teenage clichés."
Jparris is offline   Reply With Quote
Old October 24th, 2003, 11:53 PM   #8 (permalink)
JDO
JDO's Avatar
Re: Man, Tweed Champs scream STOCK!!!
jparris
i don't doubt that statement at all but my question is "what is stock"? the schem has no 25/25 cathode by-pass cap on the first gain stage but it seems that the majority of these i've read about that have been opened up have that cap in place. is that something that a tech or hobbiest put in after the fact? is it something that got writen down and as soon as fender tried it out they desided they liked it with the cap in it? or did some get sent out before everyone could remember to not put the cap in? who knows. but it's possible to have two completely stock 5F1 side-by-side where one would have the by-pass cap and the other wouldn't. and if that's the case, i could tell you which one would scream more - the one with the cap. the reason the cap was removed was to try and improve headroom. the cap in place gives the AC a free ride (as stated by mark norwine) and slams the tube hard.
so, look at your champ, if it has the cap, there's not much else i think you should do. if it doesn't, play around with different values. try a 25, try a 10, shoot, try a 1 and see which you like best. the 5E1's had a 25/25 (which to be safe go ahead and do a 25/50) like most other tweeds so that will probably be what would sound the most like a tweed.
clean as a whistle
Old October 25th, 2003, 01:00 AM   #9 (permalink)
BrianF's Avatar
your missing the mod...
It has nothing to do with the preamp tube cathode bypass.
In involves adding a bypass cap to the 1500 ohm cathode resistor of the 12AX7 that drives the power tube. The mod involves connecting that cap with a switch so that you can use it as a lead boost function. I tried it momentarily on my 5F1 champ and it seemed to work as advertised.
Old October 25th, 2003, 02:53 AM   #10 (permalink)
Marky D.'s Avatar
25-25 cap
Ah - I've got to see if mine has this cap!
I bought a completely stock otherwise pristine '59 champ at a flea market about 10 years ago but I've been underwhelmed about it's tone - even w/ a new speaker. W/ a recap, different tubes, etc. still the same...blah.
I've played others of its era that sound better, but can't figure out why mine doesn't deliver - any hints?
Marky D. is offline   Reply With Quote
Old October 25th, 2003, 04:19 AM   #11 (permalink)
Interesting replies
I appreciate the advice, I still do not have the amo in hand, but when I do, I will certainly check for that cap, and consider this mod, seems pretty simple-
Of course if the amp sounds magical stock, I will not touch it!
I've played quite a few tweed champs, I know a good one when I hear it (fingers crossed...)
