Why's it called a "coupling" cap?
Just because it's between two tubes (sometimes with some pots or other components inbetween)?
Also, anybody know a good on line glossary for all the various tube amp terms (filter cap, coupling cap, center tap, cathode, etc. and so on)?
Thanks,Nick Nec Aspera Terrent |
| Sponsored Links |
http://www.aikenamps.com/AmpTerms.html
"Coupling capacitors - capacitors which are used between stages in a guitar amplifier. They block the DC plate voltage of the previous stage, while passing the AC guitar signal on through." They "couple" two amplifier stages together. Also called "blocking" caps because they "block" DC voltage. steven |
#3 (permalink) | |
Here's my favorite definition: Modeling amp - a computer that is passed off as a guitar amplifier. See "solid-state".
I like 'solid state'
Solid-state - a component that has been specifically designed to make a guitar amplifier sound bad. Compared to tubes, these devices can have a very long lifespan, which guarantees that your amplifier will retain it's thin, lifeless, and buzzy sound for a long time to come. |
Actually, there is a variation on the coupling cap design, that allows for "signal coring," which (if done right) is supposed to result in a superior interstage signal versus traditional coupling cap (allows for more DC driving of the stages).
The problem with 'coring' is that you can end up with too big of a 'core' in the middle of the waveform. When this happens, you end up with crossover distortion (this is what occurs when the power section is biased way too cold). While I love really old amp designs, the coupling cap value choices often leave a lot to be desired. 99% of the time it's one of 3 values: .022, .047, or .1 uF. Oftentimes, if you take the time to really tweak the interstage couplers either up or down, you can end up with a much more lively amp. Just changing 1 or 2 caps can be really dramatic. I've personally had this happen with a .01 or .0047 in just the right spot. Another problem with coupling caps - leakage. When they leak, they no longer block the DC 100%. The tonal results can be horrible, and I hate tracking down the culprit(s). As a matter of typical maintenance, the couplers are not changed out, like electrolytics are. Therefore, it's easy to dismiss them altogether, and typically blame symptoms on other parts of the circuit, that occaisionally the couplers are responsible for.
