Old August 5th, 2007, 06:20 AM   #1 (permalink)
del
deluxe reverb voltage USA-europe
hi, i' thinking about buying a deluxe reverb, here in europe. I found a used deluxe reverb, usa model so it's propably 110 V ?With a good transformer to 220 V, will i be running into problems or will is just be fine, soundwise and technical ? sorry if this is a stupid question
del is offline   Reply With Quote
Old August 5th, 2007, 07:03 AM   #2 (permalink)
That should be fine - I'm assuming you mean a 220V to 110V step-down converter?
aussie52 is offline   Reply With Quote
Old August 5th, 2007, 07:26 AM   #3 (permalink)
del
yup sry that was what i ment
Old August 5th, 2007, 08:51 AM   #4 (permalink)
A warning about polarity of autotransformers
I have several step-down transformers so I can use my US amps here in Holland. Mine are "autotransformers". Instead of a true isolating transformer, these tap the 120 VAC off of the 220-240 VAC input (this is a simplified explanation). So your 120 V output has 0 and 120 VAC with respect to ground (meaning your house ground, radiator, water pipe, microphone or other guitar player). Or if you reverse the plug that supplies the autotransformer from the wall, the amp gets 120V on ground and 240V on the "hot" input. So your strings are now no longer grounded, but at 120V above ground. This is very much lethal potential. You must check that you plug the autotransformer in correctly. Some countries have wall plugs similar to the US, they can only go in one way. That helps, but always check with a meter before using in a new location. Here in Holland the wall plugs are reversible, so it's very dangerous. If you can, find a true isolating step-down transformer.
jhundt is offline   Reply With Quote
Old August 5th, 2007, 09:08 AM   #5 (permalink)
RomanS's Avatar
Make sure the step-down transformer is useable with tube-amps - those cheapo transformers you can get at hardware stores or electronics shops are usually intended only for small stuff you need when travelling (like hairdriers, razors, etc.).
TAD has a selection of appropriate transformers:
http://www.tubeampdoctor.com/index.php?cPath=27_47
Old August 6th, 2007, 06:21 PM   #6 (permalink)
If it's a newer RI, I'd say just go ahead and see if your local Fender dealer can get you a proper PT for it and be done with it. If no Fender dealer, and the TAD guys don't have what you want handy, these folks might be able to help...
http://www.shinrock.com/index.php?index
When I moved to Asia a few years back and we had 220/240, I bought the proper PT from Rivera and had it installed when we arrived. I knew NOTHING about working on electronics then. Now I know how to drain caps and I can name a few components. When we returned stateside, I replaced the original PT myself in about 10 minutes...4 nuts/bolts and a few spade connectors. Do you really wanna carry around an EXTRA 10 pounds of tranny?
A vintage DR would be a different story alltogether.
marshman is offline   Reply With Quote
Old August 6th, 2007, 06:58 PM   #7 (permalink)
RomanS's Avatar
Shinrock is currently not doing business - Ingo's daughter has a brain tumor, understandably, he has other things on his mind right now...
