Old October 18th, 2003, 07:40 PM   #1 (permalink)
Scotland's Avatar
30w + 30w = 60w ?
I used my Peavey classic 30 tonight for the first time. It was a small venue so I used it instead of my Twin. The sound blew me away, I mean really smacked me on the mouth ! The amp was set at volume 8 and the tubes were pumping red hot, the sound was incredible. Question now....I really want to keep that sound but most of our gigs would need approx. 50w tube power, if I get another Peavey C 30 and run them together in a stereo configuration through my pedals, will it be a lot louder than just the one ? I.E. equivalent say to a 50/60w amp ?
Old October 18th, 2003, 07:57 PM   #2 (permalink)
It would actually be better.
You've got two 12" speakers moving air. You've got the opportunity to spread out your sound on the stage. That said, I'd still mic the amp and run it through the PA if I needed more. That has worked incredibly well for me.
telemann51 is offline   Reply With Quote
Old October 19th, 2003, 04:41 AM   #3 (permalink)
Scotland's Avatar
Right
Yes but would it give me the same volume as a 50w ? Right now I can't get miked up as all the available mixer sockets are in use.
Old October 19th, 2003, 10:15 AM   #4 (permalink)
JWK
The answer is yes
Yes, you will double your wattage. Yes, it will be like having a 60 watt (if your classic 30 is *really* 30 watts) amp. Also, since you are doubling the speakers along with doubling the power, you will take full advantage of that power increase. The ability to spread/arrange the amps onstage increases the advantages that much more.
JWK is offline   Reply With Quote
Old October 19th, 2003, 01:04 PM   #5 (permalink)
TheGoodTexan's Avatar
Coupling
Some folks may think I'm crazy - but this is absolutely true. I've worked with my father for years, designing and building loudspeakers and home theaters. Dad's actually been in the home theater business since 1969.
There is a physical/mechanical phenominon known as "coupling". Basically it's what happens when two idetical speakers are moved away from each other on a linear plane. At a certian distance away from each other, the speakers will "couple" off of each other and become louder, and have much more bass response. Of course, both amps must be receiving the exact same mono signal. Because this has to do with phasing, when you're using a stereo chorus or delay, the effect is mostly lost.
There is a specific mathematical formula for finding the correct distance apart to set your amps, but you can just as easily find this out by playing a big clean open E chord and having a friend move one amp away from the other very slowly. Just let the chord ring out while your friend adjusts one of the two amps. You'll hear it when it happens. When you find this spot - get a tape measure and measure the distance between the center of each speaker cone from one amp to the other. This measurement is a constant for your two particular amps, so it will translate to any stage. I'm guessing it will be in the 5 to 6 foot range (just under 2 meters for our metric system friends).
For those of you that may doubt - I encourage you to try it. Also - look at any super high-end loud speakers for home theater use. Most of these companies have moved away from using larger low frequency drivers. They almost always will have two medium sized drivers...say in the 6" to 6 1/2" range, about a foot apart with a tweeter directly in the middle (there's a reason the tweeter is directly in the middle, but it's not applicable here).
This will not work if you're using two different amps.
TheGoodTexan is offline   Reply With Quote
Old November 5th, 2003, 03:20 PM   #6 (permalink)
Scotland's Avatar
Re: It would actually be better.
Would you believe it? We have just bought ourselves a whole new P.A. and now I can mike up my classic 30. Bought myself a Sure SM57 to do the job. Will let you know how it turns out.
Old November 5th, 2003, 03:38 PM   #7 (permalink)
Ben Harmless's Avatar
Re: Coupling
Ha! Let's seee LIne 6 model that!
I've been working live sound for clubs and outdoor events for almost a year now, and I'm only beginning to appriciate some of the amazing phenomenons that occur based on speaker placement, direction, size, and location. I also just managed to scrounge up a couple of speakers, so now I have a cabinet for my Marshall and a cabinet for my Reverend. Look out folks, it's the double Ben attack!
- B. Simpson
Old November 5th, 2003, 04:36 PM   #8 (permalink)
It will sound great. I couldn't believe how good it was out front with the guitar coming out of the mains instead of from a single point behind me. I used an SM57 as well. I put the mic right up against the grill cloth, about midway between the center and edge of the speaker cone.
Old November 5th, 2003, 04:48 PM   #9 (permalink)
Coupling effect
So I'm assuming that the coupling effect described by TheGoodTexan would occur with one amp and an extension cab, no?
Hucklebilly is offline   Reply With Quote
Old November 17th, 2003, 09:01 AM   #10 (permalink)
Scotland's Avatar
Fantastic
That's all I can say about the sound !
Just got to get decent monitors now to appreciate it fully.
Old November 17th, 2003, 07:20 PM   #11 (permalink)
feojack's Avatar
Re: Coupling effect
Yes I was wondering that too. I may be rather thick, but it wasn't clear to me either.
Cheers, feo
"Those who danced were thought to be quite insane by those
who could not hear the music." - Angela Monet
feojack is offline   Reply With Quote
Old November 18th, 2003, 02:22 AM   #12 (permalink)
Scotland's Avatar
Re: Coupling effect
Cheers, feo
Count me in on the thick club, I was wondereing the same thing. :?
Old November 18th, 2003, 09:48 AM   #13 (permalink)
Re: Coupling effect
Cheers, feo
Just noticed these replies/questions...
Coupling is actually easier to achieve with a combo and ext cab, IF the ext cab is identical in inside dimensions as the combo, and has the same speaker (including impedence) as the speaker in the combo.
It's easier this way because you're only working with one preamp/amp, insuring that both speakers are receiving the exact same signal at the exact same level.
Originally Posted by Sidney Vicious
If there's anything worse than whining its whining that your whining isn't being heard.
Old November 24th, 2003, 08:17 AM   #14 (permalink)
Scotland's Avatar
Thanks
Now all I have to do is find an extension cab for the C30....it's like looking for hen's teeth !
Old November 24th, 2003, 10:10 AM   #15 (permalink)
Re: Thanks
You mean one that matches up nicely with the appearance? I don't think there is one. At least not an open-back 1x12. There's a closed-back 4x12 in black tweed, and an open-back 4x10 in regualr tweed, but no 1x12.
I'd go with Avatar for an open-back 1x12 if I were going to try to set up a coupling effect with a Classic 30.
Remember impedance. I seem to recall that running an extention cab along with the internal speaker of the Classic 30 is something of a chore.
- B. Simpson
Old November 24th, 2003, 11:29 AM   #16 (permalink)
Scotland's Avatar
Yep
The C30 is 16 ohm. Peavey used to make an ext. cab for them but don't now. I keep searching ebay for one but have not seen one yet.
Old November 24th, 2003, 12:02 PM   #17 (permalink)
KC
Here's an idea
why not just buy another C30? you could use it for an extension cab or just take a y-cord and run 'em both. That way if your amp goes South in the middle of a set you can just keep playing. It seems like they're going for as little as $200 on ebay and an extension cab isn't going to be much cheaper than that.
KC is offline   Reply With Quote
Old November 24th, 2003, 02:25 PM   #18 (permalink)
Re: Here's an idea
That's the best idea I've heard in a while. If one amp craps out, use the other one to power both cabs. You'll never have to worry about amp failure.
Old November 24th, 2003, 04:59 PM   #19 (permalink)
Scotland's Avatar
Great idea, didn't think of that
As it turns out, an ext. cab for the c30 112e has turned up on ebay, if I get it then fine, if not, I'll go for another c30. Thanks guys.
Old November 25th, 2003, 03:38 PM   #20 (permalink)
11 Gauge's Avatar
C30 and impedance...
actually there should be an external out plug on that C30. i think the O.T. tap for that one is actually 8 ohms...
i seem to remember reading a recommendation to grab an 8 ohm speaker for the C30 and run it off the external cab jack...
if you can find one, you may want to grab a Peavey Delta Blues 1X15. i've got one and that sucker moves some air - a very loud 30 watts, and fantastic with a Tele. You could then optimize your setup with the C30 tweaked just so, and the DB tweaked just so...
a used DB should be on par with the cost of a used C30...
Old November 25th, 2003, 05:15 PM   #21 (permalink)
C30 extension speaker
The C30 speaker out is 16 ohm. You need a 16 ohm speaker in the extension cab, just like the main speaker. Coupled together, the load is 8 ohms.
I've got the 112 E cab with a 16 ohm Celestion. Sounds great.
Bob
Bob McLeod is offline   Reply With Quote
Old November 25th, 2003, 05:23 PM   #22 (permalink)
Re: C30 and impedance...
The jack on the ext out switches to the 8 ohm tap. That way it matches the impedance of the 16 ohm internal speaker and a 16 ohm external one wired in parallel.
If you use an 8 ohm speaker in the C30, you can't wire it the internal way. You have to plug it into the ext out and tape the ends of the internal wires.
Old November 26th, 2003, 02:31 PM   #23 (permalink)
11 Gauge's Avatar
that's what i thought...
i believe Steve Ahola at the Blue Guitar was the one who pointed this out. he's partial to some 8 ohm Celestion model in his.
thanx for the clarifications - yes, if you want to drop to 8 ohms you have to do it off the ext. jack only and tape off the leads for any internal speaker.
FWIW i tried a Weber VST 8 ohm off the ext. out, and didn't really notice a difference. maybe i'm going deaf...
or, you could buy a truckload of C30s off of ebay and run any impedance you want. as they blow up, send another soldier or 2 up to the frontline... if you can't have a mil-spec amp, then have a small army of cheap amps - the audience may even take it for part of your stage show.
11 Gauge is offline   <
