No, not really. You can do it (patching from the Normal channel to the Reverb channel), but the extra stages in the reverb section will cause an out of phase situation with the normal channel and will make it sound awful. Try it. It won't hurt anything.
Ironically enough, you can patch one channel of one AB763 amp into one channel of a different AB763 amp and not have that out of phase problem. It sounds pretty good actually (but you have to haul around two amps). Or, with a couple of adaptors, you can take the recovery signal from the reverb tank (the cable on the left, when looking at the back of the amp) and put that into the input of the Normal channel. I've heard guys use that before. The cabling is sort of awkward, but it works. |
I've done it.
It wasn't pretty! I've also done it on a 62 Tremolux. It was GOD-like! Any two channel amp without reverb should be fine. I've done it on the old Silvertone heads too, with the same results.
Timothy Jon Lamb |
You can usually double check by looking at the schematic. Every time the signal goes through a tube (gain stage) it's inverted. So long as the channels have the same number of gain stages, you'll be just fine.
I've heard people swear that their amp became better when they jumpered their two-channel amps with 'verb, but I've never actually seen those people playing like that...
"I think I'll go for the life of sin, followed by the last-minute, presto-change-o, deathbed repentance." - B. Simpson |
I agree with the "try it". Phase shift through the amp's various stages isn't exactly 180, and messing with the tone controls will cause additional phase shift.
I did it on a SFDR, and wasn't all that thrilled....and made a single stage trasistor inverter 'box' for that purpose. Still wasn't thrilled... |
#7 (permalink) | |
here's a trick.
Use an effect pedal that shifts the phase by 180deg in the jumper loop. That way the signals that are summed before the PI are in phase. I think some clean boost pedals will work. Thay way you can get a linear equalization across the spectrum. IIRC, my Super Hard On is out of phase with the input signal. YMMV. Justin |
