fundraiser
Old July 3rd, 2007, 09:03 AM   #1 (permalink)
weelie's Avatar
How does the Noise gate on the VOX AD5 work?
I tried the Vox AD5 last weekend in a local shop. Very noisy (even with no input and everything on zero), I felt. The effects were useless because the repeated the scratchy noise. I did like the "tweedy" tone it had. My experience was similar to when I had a Behringer GM110. It had a great basic tweedy tone, but also some hiss. Sold it as it didn't have reverb and didn't sound good enough with my tele (with the strat is sounded fine).
So I read it has a noise gate? How does one operate it (sorry, it might be blatantly evident, just didn't see it)? Can you have it on regardless of other settings? Does it alter the tone in bad way? Do you have it on?
<- I don't need smileys, I'm smiling already.
weelie is offline   Reply With Quote
Old July 3rd, 2007, 09:38 AM   #2 (permalink)
ruger9's Avatar
The noise gate works in conjunction with the effects- the noise reduction levels are pre-programmed to levels that match the amp type & effects you are using (i.e., more noise reduction on the high-gain amp models.)
The noise gate is manually adjustable with the same controls that adjust the effects. I don't know exactly how because I don't use the noise gate feature. I think you hit the "bypass" button, which turns the effects OFF, then use the effects adjustment knob & tap tempo button to set the noise gate. My DA5 is not noisy... especially on the "tweedy" setting ("Blues 1" or "Blues 2" ,BTW, is the Fender Bassman model). It sounds like there might have been something wrong with that particular DA5?
Old July 3rd, 2007, 12:43 PM   #3 (permalink)
How is the grounding where you play? I have experienced a lot of hiss from a Vox AD30VT at a dealer's, where the grounding seems to be poor and the lighting seems to cause interference. Of course it gets worse with single coils.
Klas
...all the times I've had to play while people sat there drunk...
klast is offline   Reply With Quote
Old July 3rd, 2007, 12:59 PM   #4 (permalink)
aznrambo481's Avatar
i have the vox AD30vt. when it's in bypass mode (for the effects) hold tap and turn the knob. turning it CCW will turn noise gate on more (I think). If you turn it all the way up you lose sustain horribly. The grounding on the AD30VT is pretty good.
Check out my bands, and feel free to PM me comments on them!
The Eclectics (guitar/vocals)
SLIP (bass)
aznrambo481 is offline   Reply With Quote
Old July 3rd, 2007, 05:05 PM   #5 (permalink)
weelie's Avatar
I'll try to go to the store again and check the grounding issue. The thing is I am torn between the DA5 and the microCube, wanting to love the DA5, but the hiss was annoying.
Old July 4th, 2007, 03:31 PM   #6 (permalink)
david henman's Avatar
...my da5 has zero hiss.
-dh
david henman is offline   Reply With Quote
Old July 5th, 2007, 04:24 AM   #7 (permalink)
eddiewagner's Avatar
give the da5 another try. i really dig mine and use it a lot. the microcube does not have one good clean sound at useable volumes, its always farting.
My Drum/Guitar-Duo:
www.myspace.com/captaintwangandhisrhythmcat
