Old July 1st, 2007, 05:38 AM   #1 (permalink)
OLAF MELCHER's Avatar
Phase Inverter Substitution
Hi guys,
does anybody know if one can safely substitute a 12AT7 tuby by a 12AX7 tube in SF Vibrolux Reverb and SF Super Reverbs without damaging the amp ?
Thanks
jazzjoker
OLAF MELCHER is offline   Reply With Quote
Old July 1st, 2007, 07:16 AM   #2 (permalink)
zook's Avatar
yes you can it provides more gain and earlier breakup
Winnie
I have noticed that happy people are often evaluating themselves and unhappy people are always evaluating others. -William Glasser
zook is offline   Reply With Quote
Old July 1st, 2007, 08:07 AM   #3 (permalink)
EMan's Avatar
12AT7 tubes have a lower effective plate resistance than a 12AX7.
If you run your amp bias 'hot' ( like a lot of folks tend to do ), the amp may be running the output tube grid(s) positive. With lower available plate current via the 12AX7, it will have less ability to drive the output tube(s).
A 12AX7 can also, for the same reason, make it harder for the output tube grid to 'unload' possibly contributing to blocking distortion.
Will the substitution hurt anything....as mentioned above, nope.
EMan is offline   Reply With Quote
Old July 1st, 2007, 10:27 PM   #4 (permalink)
You might want to try a 5751 also. A little less drive than a 12ax7 and a little more than a 12at7.
nonvintage is offline   Reply With Quote
vB code is On
Forums Directory
