Old May 27th, 2007, 06:51 AM   #1 (permalink)
mr_hankey's Avatar
Replacement caps for Astron Minimites?
I recently bought a G6G-B '64 Bassman, which (electronically) is in good shape. The previous owner took good care of it, so it's functioning perfectly. I did however, notice that some of the filter caps look like they need replacement.
What should I replace them with? AFAIK, filter caps don't affect tone, but I want to make sure the replacements are as similar as possible.
http://www.tubeampdoctor.com/index.p...6ecd4ae2c7764f
Which out of these would be best? Or should I look elsewhere?
Also, what are some good power tubes for it? I've got Sovtek 5881WXT's in there right now, which aren't really doing it for me.
Thanks!
mr_hankey is offline   Reply With Quote
Old May 27th, 2007, 09:04 AM   #2 (permalink)
Dacious's Avatar
I would suggest Spragues for best fit in Fenders and to retain value. The blue filter caps are available in various values from 8-100uf and voltage ratings from 350-500v. The smaller but long black ones in 100v work for the bias and the smallest as signal path caps.
Lots of vendors sell these - Doug Hoffman does, so does Triode Electronics. I've used the black Nichon/Ixion (?) ones in a Vibrosonic where the owner was budget minded and in a hurry and they sounded fine and still work OK several years on, but they look strange inside the doghouse as they're so small.
My view is 20 or more y.o. old electro caps regardless of how good they were new; if they are worn do adversely affect tone by attenutating frequencies and losing bass repsonse either in the power supply or in the tone stack. It's one of those things you change and then realise how much you were missing.
I've had good success in homebrews and low-value amps with the small black caps especiallly where space is an issue. In a Fender vintage amp I'd use the Spragues as a preferrence because they are a good product and fill the space well plus they are not dear. Plus they are a good product and show you cared about the amp.
For tubes - another can of worms. I like Svets. I have Sovtek 6L6WXT+ (not the military '5881') in my Vibrolux at present and have been happy with them. Many swear by the JJs.
Old May 27th, 2007, 11:16 AM   #3 (permalink)
mr_hankey's Avatar
How would the Sprague's affect tone? I've heard that they are quite bright, but is that only the case with the signal caps?
Old May 27th, 2007, 01:26 PM   #4 (permalink)
Filter caps do change tone. Replacing old worn caps will make the amp sound more full and can get rid of hum.
The blue spragues recommended are the standard and many have said sound better than jj's or generic asian (i believe if i'm not mistaken, but correct me if i'm wrong, jj's are generic asian caps just relabeled).
What's more is that if you don't replace them and you keep playing, it's just a matter of time before one goes and leaves a nasty mess.
geoffreysnow is offline   Reply With Quote
Old May 27th, 2007, 03:44 PM   #5 (permalink)
mr_hankey's Avatar
Yeah, I've seen it before.
Well, thanks for the help, I'll order some Spragues very soon!
Old May 27th, 2007, 11:28 PM   #6 (permalink)
CancerLeoCam's Avatar
I'd recommend Xicon. I still use the Spragues for the high-end amp models I build but the Xicons are stout and are mucho smaller in size and inexpensive compared to the Spragues.
Retail a Sprague 20uF/500V will cost you $6.50 a piece. The Xicon 22uF/450V will cost you $2.10.
For six of the Sprague filter caps your cost would be $39.
For six of the Xicon filter caps your cost would be $12.60.
A great alternative.
Everyone's your buddy when they want you or something from you.
If you're not willing to work for free why should somebody else?
CancerLeoCam is offline   Reply With Quote
Old June 24th, 2007, 02:48 PM   #7 (permalink)
mr_hankey's Avatar
I don't mind paying a little bit more for quality; but if the difference is negligible, I might as well go for some Xicons.
Should I also be thinking about replacing the signal caps? They don't show any visible signs of (imminent) failure; but the fact that they are 40+ years old might be reason enough.
Old June 24th, 2007, 04:18 PM   #8 (permalink)
dibber124's Avatar
I have been an amp repair tech for over 35 years, and always use Sprague Atom caps in Fender amps. What you heard about bright sounding Sprague caps refereed to the "orange drop "715. The sound of these caps seemed to change about ten years ago. Now I use Mallory 150's. Just cannot bring myself to use cheapo caps in my repairs, although Panasonic and Nichicon caps are excellent. N/A in axial configuration or I would use them.
"I feel that it is healthier to look out at the world through a window than through a mirror. Otherwise, all you see is yourself and whatever is behind you." - Bill Withers
dibber124 is offline   Reply With Quote
Old June 24th, 2007, 04:18 PM   #9 (permalink)
RomanS's Avatar
F+T caps (as sold by www.tubetown.de ) are supposed to be very high quality, too!
Old July 28th, 2007, 11:21 AM   #10 (permalink)
mr_hankey's Avatar
I've replaced the filter caps with Sprague Atoms, but I haven't had a chance to fire it up and test it yet.
I did notice, while poking around in the amp, that the 25+25 Mallory signal caps are also showing signs of bulging. Are Mallory 150's the way to go here?
Old July 28th, 2007, 12:25 PM   #11 (permalink)
25/25 is also an electrolytic. Replace those too. if you don't want to use a dual 25 (F&T makes one) you can use two seperate 25uf caps wired next to eachother.
you also need to replace the one above the power transformer in the pic above on the small board with the diodes next to them.
Old August 1st, 2007, 11:46 AM   #12 (permalink)
mr_hankey's Avatar
^Right. Which ones do you guys recommend?
Old August 1st, 2007, 03:53 PM   #13 (permalink)
Rusty's Avatar
Luxe???
http://stores.ebay.com/Luxe-Guitars
seen these on ebay for a while...have no idea if they're any good? they look cool, but i haven't heard any reports on them...
Take it easy,
Rusty
www.myspace.com/1rusty
www.rustyanderson.net
Rusty is offline   Reply With Quote
Old August 1st, 2007, 04:01 PM   #14 (permalink)
Those are repro caps - basically new stuff in cases to make it look like the old. pretty sure their filters are just xicons and their signal caps are sprague 150's? nothing special, look like the old, but you can just use what was recommended above (sprague atom/f&t) and it'll be cheaper and possibly even better.
Old August 5th, 2007, 10:48 PM   #15 (permalink)
Rusty's Avatar
good to know...thanks!!!
Take it easy,
Rusty
