Old May 21st, 2007, 11:03 AM   #1 (permalink)
Coupling/bypass caps in '72 Deluxe Reverb
While doing a full Cap Job this weekend in my AB868 silverface Deluxe, I noticed that the circuit seems to be "missing" some of the caps that the AB763 circuit has. From right to left the AB763 circuit has three pairs of 25uf 25v caps, and then one in the vibrato section. However, only the far right set was there. The other two had only one 25uf 25v cap. Since this stage of the circuit seems virtually identical to the AB763 one, why the "missing" caps? Should I add them?
Any help would be most appreciated.
Geschwader is offline   Reply With Quote
Old May 21st, 2007, 04:54 PM   #2 (permalink)
Bluesbob's Avatar
Are you sure they're not just different makes? I know my '73 DR had all the same kinds of bypass caps, but it's possible Fender started to use a new batch right in the middle of assembling your amp.
What, me worry?
Bluesbob is offline   Reply With Quote
Old May 21st, 2007, 07:31 PM   #3 (permalink)
jjmantele's Avatar
Sounds like a possible "mod" to reduce gain and reverb?
A1270 is probably the era for your amp. PI component values are different from AB868.
JJman
If it says "Vintage" on it -it isn't.
jjmantele is offline   Reply With Quote
Old May 22nd, 2007, 10:46 AM   #4 (permalink)
I bought this amp 25 years ago from the original owner. No mods were done, and from the look of the circuit board, the full allotment of caps was never there to begin with. Very odd....
Old May 22nd, 2007, 02:37 PM   #5 (permalink)
Bluesbob's Avatar
Need a picture.
What, me worry?
Old May 22nd, 2007, 04:17 PM   #6 (permalink)
Check the backside of the chassis. In the SF era, Fender moved a couple of bypass caps to ground points on the back panel.
Old May 22nd, 2007, 04:29 PM   #7 (permalink)
Chris Callahan's Avatar
I noticed this in my 72 SF Twin. Any idea why? When I recapped it, I wired it like the "layout". It didn't make any apparent sonic difference.
Chris
Chris Callahan is offline   Reply With Quote
Old May 22nd, 2007, 04:38 PM   #8 (permalink)
Chris, I don't have any idea...other than that when you have EE's on the payroll, they have to do something, right?
