Old May 19th, 2007, 09:02 AM   #1 (permalink)
Blues Jr's Avatar
I'd like my DRRI to break up earlier...
Hey there...
I'm not totally interested in "clean" headroom. I'd like my DRRI to get crunchy sooner on the volume knob. The amp starts to break up now around 5-6. Anything I can look into? Tubes? Speaker? I was planning to order a full set of JJ's, but I'd thought I'd ask first.
I have the stock tubes right now, and a Jensen P12Q.
Blues Jr is offline   Reply With Quote
Old May 19th, 2007, 09:58 AM   #2 (permalink)
zook's Avatar
Originally Posted by Blues Jr View Post
Hey there...
Swap the 12AT7 Phase inverter for a 12AX7. That's the tube next to the 6V6.
Winnie
I have noticed that happy people are often evaluating themselves and unhappy people are always evaluating others. -William Glasser
zook is offline   Reply With Quote
Old May 19th, 2007, 10:36 AM   #3 (permalink)
tonytrout's Avatar
What do y'all mean by "amp break up"?? Please explain.....in simple English.....
tonytrout is offline   Reply With Quote
Old May 19th, 2007, 10:39 AM   #4 (permalink)
Jeffscreamedcorn's Avatar
When the amp starts to distort.
Jeffscreamedcorn is offline   Reply With Quote
Old May 19th, 2007, 10:48 AM   #5 (permalink)
Mine (SFDR) actually starts to break up at 2/3 on the volume dial. No idea why it does this, but it still sounds great, so I've never bothered with trying to "fix it".
The Weber Mass works great with the DRRI. Since the amp is pretty small to begin with, you don't really have to attenuate that much to bring volume down, while still having the amp break up nicely. Highly recommended.
teXum is offline   Reply With Quote
Old May 19th, 2007, 11:39 AM   #6 (permalink)
The bias may be set 'cold'. When you get your JJ's, have the bias adjusted to something around 70% of plate dissipation. Zook's suggestion on the 12AX7 will heat up things, too. IF that doesn't get it going for you, there are other things to do. Adjusting the resistance in the negative feedback loop gets an amp up into the hot and rich zone. Changing the PI cap from
.001 to .01-.02 brings in more mids. The preamp cathodes can be separated and gain increased. all sorts of things to do....of course, the PCB RI is not as easily worked on as a vintage DR, but there it is.
Old May 19th, 2007, 12:44 PM   #7 (permalink)
Glen W's Avatar
What guitar are you using? For instance, I can plug a Strat into my PR, DR, or SR, and stay pretty clean to 4 or 5. Plug in a Tele, and it may get greasy a little sooner using the bridge p/u. If I plug in the P90 Les Paul, I'm getting the grit at 3.
Glen W is offline   Reply With Quote
Old May 19th, 2007, 03:43 PM   #8 (permalink)
PhatTele's Avatar
1) Make sure it's biased correctly. If it has the factory bias, it's probably too cold. Use the following table to set the bias (w/a GZ34 rectifier, I usually set it up around 21-23mA per tube):
http://members.shaw.ca/house-of-jim/...as_tables.html
2) If that doesn't do it, try a 5V4 or 5R4 rectifier and rebias. This will drop the plate voltage and allow you to bias hotter (using the tables above) and will create more sag...don't use a 5U4 in your amp. I don't think the power transformer is set up to handle the extra current draw those require.
3) Figure out how to add a midrange control. Basically, you will replace the resister tied to the Bass control pot (a 6.8K value) with a audio taper pot (I like 25K). Stick the pot in place of the ground switch (the ground switch doesn't have anything connected to it anyway in those reissues...it's just there for show).
4) As someone mentioned above, swap the phase inverter tube (the 12AT7 next to the power tubes) with a higher gain 12AX7.
5) Remove the first preamp tube (the one furthest away from the power tubes). This will increase the bias on the preamp tube tied to the reverb channel, thus giving you a bit more gain.
If it were a SF or BF version, there are other things you can do (easier to get at the components).
Old May 19th, 2007, 04:00 PM   #9 (permalink)
formerly "Big" Mike Simpson
Mike Simpson's Avatar
Turn the bass and treble down to 2 to 4...
Mike Simpson is offline   Reply With Quote
Old May 19th, 2007, 09:31 PM   #10 (permalink)
Blues Jr's Avatar
Hey thanks for all your suggestions.
My amp is probably biased cold, it's a few months old now and never had it worked on. Maybe a good set of tubes and rebias to start and go from there.
Are certain tubes higher gain than others? For instance, are JJ's any different than Tungsol or TAD?
Thanks.
Old May 19th, 2007, 09:43 PM   #11 (permalink)
zook's Avatar
Thanks.
It's not neccessarily the Brand as much as the tube type. The greater the amplificatrion factor, the more gain you'll get. Check this out:
Tube substitutions
Drop in for 12AX7
Tube type - Amplification factor
12AT7- 60
12AU7- 17
12AV7- 41
12AX7- 100
12AY7- 44
12AZ7- 60
12BH7- 16.5
(draws twice the filament current)
12BZ7- 100
12DM7- 100
12DW7- 100/17
12DT7- 100
5751- 70
5814- 17
5963- 21
5965- 47
6072- 44
6189- 17
6201- 60
6679- 60
6680- 17
6681- 100
6829- 47
6913- 18
6955- 16.5
7025- 100
7247- 100/17
7318- 16.5
7728- 60
7729- 100
7730- 17
Winnie
Old May 20th, 2007, 12:46 AM   #12 (permalink)
PhatTele's Avatar
For now, Don't worry about getting "hot" rated power tubes. Just get your amp biased properly with the tubes that are already in it. I'm sure they're fine, whatever brand they are. Use that point as your benchmark to adjust your tone. If you change too many variables all at once, you'll never know what "the fix" was.
Old May 20th, 2007, 10:22 AM   #13 (permalink)
zook's Avatar
To check the Phase inverter swap you can do that quite easily. Take the 12AX7 from V1 (that's the non reverb channel) and the 12AT7 fro m the phase inverter (the one next to the 6V6) and swap them. Play through the Vibrato channel and see how it sounds to you.
Winnie
Old May 20th, 2007, 10:41 AM   #14 (permalink)
Speaker Change..
might really do the trick, if you're not satisfied with all the great suggestions on the tube swaps.
For my PJ, I tried all sorts of tube changes as well, but nothing really nailed the early breakup tone that I was looking for, until I swapped out the stock speaker for a Weber Alnico -- which was specifically designed for providing earlier breakup. The combination of the output tubes with the earlier breakup of the speaker enhanced my tone significantly.
Just my two cents.
slideman is offline   Reply With Quote
Old May 20th, 2007, 06:06 PM   #15 (permalink)
the RFT 12AX7 (an east german tube) has lower headroom and will break-up sooner than most other 12AX7's.
The Radium King is offline   Reply With Quote
Old May 20th, 2007, 06:29 PM   #16 (permalink)
Hey there...
What are your tone controls and reverb set on when "The amp starts to break up now around 5-6."
