fundraiser
Old May 15th, 2007, 10:20 AM   #1 (permalink)
BootRoots's Avatar
SF Princeton Reverb. Help!
So I was playing my SF 68 Princeton Reverb the other day and the volume started swelling for no reason. Kinda faded in and out, and then....just out. Now when I turn the amp on there is a humming sound that fades out after about 3-4 seconds. There also seems to besome kind of buzz or rattle comming from some where near the rectifier tube. I get absolutly nothing when I plug it in though.
Needless to say I will be taking it back to the tech to have him answer some questions about his work (i just had it in there to be looked at and he replaced the power tubes and say everything looked okay), but I was wondering if anyone here might be able to help out. Does this sound like a tube thing? help.
Thanks
BootRoots is offline   Reply With Quote
Old May 15th, 2007, 10:28 AM   #2 (permalink)
dibber124's Avatar
Thanks
Suggest that you have the condition of the filter caps checked.
"I feel that it is healthier to look out at the world through a window than through a mirror. Otherwise, all you see is yourself and whatever is behind you." - Bill Withers
dibber124 is offline   Reply With Quote
Old May 15th, 2007, 02:46 PM   #3 (permalink)
Jef
Jef's Avatar
In a princeton reverb, the filter caps are in one can cap, behind the power tubes. Those are a pain to remove (sometimes soldered to the chassis) and you probably won't find a replacement of the same values and size. never saw one of those can caps go wrong, however. Looks like they are more durable than the 'normal' axial electrolytic caps.
does the pilot light come on?
Jef
Amplification is not a social dinner, a literary event, a drawing or an embroidery; It cannot be done with elegance and courtesy. Amplification is an act of violence... (Mao Tse-Tube)
Jef is offline   Reply With Quote
Old May 15th, 2007, 02:55 PM   #4 (permalink)
BootRoots's Avatar
Jef
yes the pilot light comes on.
Old May 15th, 2007, 08:56 PM   #5 (permalink)
PhatTele's Avatar
It sounds like "a tube thing" to me.
Meanwhile, Antique Electronic Supply sell direct replacements for those cap cans (see link)
http://www.tubesandmore.com/scripts/...m=C-EC20X4-475
Old May 16th, 2007, 09:51 AM   #6 (permalink)
BootRoots's Avatar
thanks for the heads up. I'm gonna swapp the tubes and see what happens. after that its off to the tech.
Old May 16th, 2007, 11:26 AM   #7 (permalink)
Make sure you check the Rectifier tube also, and don't be too hard on your tech. it's impossible to diagnose problems that havn't occured yet.
"Ahh...beer, the cause and the cure of all man's problems" Homer Simpson
145Guy is offline   Reply With Quote
Old May 16th, 2007, 02:32 PM   #8 (permalink)
BootRoots's Avatar
I hear ya. hes worked on several things for me in the past and always done right by me, so I will give him the benifit of the doubt.
Old May 16th, 2007, 03:17 PM   #9 (permalink)
Tim Swartz's Avatar
Yep, swap in a rectifier.
