Regarding square drive screw found in Fender amp
I was wandering if anyone has encountered a square drive screw in any Fender amps. It may have been put in at any time, but I know Fender has used the occassional odd part/hardware. I have not encountered this before. It is in the cabinet of a Brownface Princeton.
Pic of square drive screw. 1024x768 Pic of other screws in same cab. 1024x768 |
| Sponsored Links |
Not that I know everything, but I've never seen a screw like that on a Fender product. It looks like a galvanized screw, while everything else is stainless. I'm pretty sure that some do-it-yourselfer used that screw to replace one that was missing or corroded or something.
neither screw looks original. i think this amp has been worked over...
and ampegs gon't use square head, they use clutch head
"Progress is not possible without deviation from the norm." Frank Zappa |
#7 (permalink) | |
Re: Robertson head screw
J.R.
It didn't make that smell when it was new, PULL THE PLUG! |
#8 (permalink) | |
Another amp. And here's my pic again: This amp. Nonetheless, one can not conclude from my two pics that the amp has been "worked over". |
[quote="slackNonetheless, one can not conclude from my two pics that the amp has been "worked over".[/quote]
Maybe Mark saying "worked over" implies a little more work having been done, but the screws aren't original. That much we can conclude :-) Having said that, I think it's kind of rare for an amp to have just a couple of screws replaced and not had other work done too. |
#10 (permalink) | |
Okay, here's the findings. Non-original parts are that one screw, the replacement leather handle, three capacitors (neccessary maintenence), and a three prong power cord. Chassis, tube chart, transformers, speaker, and all pots correspond. I was a bit suspect that the grille cloth was original because it is so clean, but it does not appear to have been replaced. Some chassis wiring pics: Chassis bottom. 640x480 Internal wiring 1. 640x480 Internal wiring 2. 640x480 Power cable wiring. 640x480 |
