Old September 20th, 2003, 02:40 AM   #1 (permalink)
Honga Man's Avatar
And just WHY don't I have a Musicmaster Bass amp yet?
I thought I was fairly Fender-savvy, but I've only recently become aware of the existence of the Fender Musicmaster Bass amp, a 12 watt combo with 12" speaker.
Those controls are just what I want, except maybe I could do without that fancy "tone" control.
The price certainly is right and apparently even cool mods are dirt cheap.
Is there any reason I shouldn't buy one for home use?
Anyone have one for sale?
Honga Man is offline   Reply With Quote
Old September 20th, 2003, 10:04 AM   #2 (permalink)
Honga Man,
plan on $135-$150 depending on how pristine the piece
is, most of the ones I've seen that were good were at $135, they're on E-Bay all the time. Good Hunting!!
Somebody Loan Me A Dime
stantheman is offline   Reply With Quote
Old September 20th, 2003, 08:38 PM   #3 (permalink)
There are TWO..
Versions of this..the later one has 6v6's (traditional Fender tube)..early versions have something else (6BQ-5..aka el-84 ? )..I would go for the 6v version if possible.
there are also two types of knobs..early "Zodac" sheetmetal knobs..later traditional BF/SF knobs.I DONT KNOW that the knobs changed with the tubes..also for real fun try finding one of the ones from the early '80s with the second version BF lettering!! All had a cruddy speaker..plan on changing it esp. if you want to use it for bass.
Loud is Good...
buglecorps is offline   Reply With Quote
Old September 21st, 2003, 02:10 AM   #4 (permalink)
Honga Man's Avatar
Thanks for the advice.
I assume from the beginning that I will need a replacement speaker. I plan to use this as an amp for my Tele for solo practice/home recording and jam sessions (a specific one with friends where we don't get very loud) and maybe low-volume (like home recording) for bass if I don't just go direct.
I know from experience not to play loud bass through a guitar amp speaker!
I do have a good amp tech, one of those old-school guys with the factory service manual for every tube amp ever made in his dusty old file cabinet. In addition to a new speaker, I plan to take it straight to him for a complete check up/maintenance visit right after I do some cosmetic cleanup if necessary.
So, for use with a Tele for the traditional Fender sound, any speaker recommendations or mod advice for this Musicmaster Bass amp newbie?
What sounds good and is suitable for this amp?
8 ohm or 4 ohm?
Thanks for any advice! :D
Old September 21st, 2003, 06:55 AM   #5 (permalink)
Rob DiStefano's Avatar
Re: There are TWO..
Originally Posted by buglecorps
... early versions have something else (6BQ-5..aka el-84 ? )...
6AQ5 - this is not an EL84.
IMO, the 6AQ5 is a tasty tube and there are plenty to be found and all are cheap. Either tube version of the MMB will satisfy. Swapping out the speaker is a must, IMO.
Old September 21st, 2003, 11:53 PM   #6 (permalink)
Thanks Rob..
I couldn't rember what they were...I owned one with those and it alwas seemed a little "lacking" probably could have used a service!I played one with 6v's a few months ago, and was stunned by the big full sound, with a P Bass..it was really pushing that stock speaker though!!
Loud is Good...
Old September 22nd, 2003, 06:08 AM   #7 (permalink)
Originally Posted by Honga Man
... So, for use with a Tele for the traditional Fender sound, any speaker recommendations or mod advice for this Musicmaster Bass amp newbie?
8 ohm or 4 ohm?
MMB's require an 8 ohm speaker. I've tried more than a few and prefer the Weber 12A125 (P12Q), but there are many good cheaper alternative speakers like the Naylor 12" and Jensen reissue C12N.
Old September 22nd, 2003, 05:31 PM   #8 (permalink)
Love my Musicmaster Bass amp
I had mine overhauled- cap job, new 6V6 tubes, and a Celestion speaker. It is lightweight, simple, and has sound to die for. I use it for gigs- just mic it on stage. I couldn't be happier. I put the volume and tone knobs on about 5 or 6 and it is good to go- clean when I back off the volume knob on the Tele, bluesy grit when I turn up the Tele. It responds great to an O/D pedal when I want to take it over the top for creamier distortion. If I dime the volume knob, I can get ZZ-Top or Zeppelin style full distortion just from the amp alone but it is too loud to dime it in our band's practice studio. I have to use the O/D to get full distortion when in the studio or else it's just too loud! Since I'm used to using the O/D pedal in the studio, I usually stick to the same setup on the road just to keep things easier for me. It has no reverb, but I use a little slapback echo with an old Ibanez pedal once in awhile. I'll say it again-- tone, tone, tone!
chris m.
chris m. is offline   Reply With Quote
