Old January 6th, 2007, 12:07 AM   #1 (permalink)
Reverb kit recommendations
I just finished a Marsh Champ kit and now would like to tackle a reverb kit. I see that Weber and SFT have some. Any comments on those and others out there?
larry
Larry F is offline   Reply With Quote
Old January 11th, 2007, 08:14 AM   #2 (permalink)
I have a Weber revibe kit. That's the one with reverb & tremolo. Difficult build. Reverb alone is much simpler. Only knock on the Weber kits is the switches, pots, jacks, and pilot light are not US made quality, and the jacks are wired different than US types. Everything else is pretty good. No instructions, but they do have a schematic & layout online as well as a kitbuilders bulletin board for help. Sounds good and is the most reasonably priced kit out there. If you go with a Weber kit ( or even another), check out Jeff Gehring's modified grounding scheme (search the kitbuiders page). It makes for an extremely quiet running unit. He uses a floating ground buss that has a resistor before ground. Prevents noisy ground loop problems. Best luck with your build!
chaz is offline   Reply With Quote
Old January 11th, 2007, 04:58 PM   #3 (permalink)
Thanks, I've ordered the Weber regular reverb (without tremolo). Thanks for the grounding tip.
larry
