Old December 21st, 2006, 03:50 PM   #1 (permalink)
Twin Reverb Reverb issue
I've got a beat up old SF Twin Reverb that I've put a bunch of work into that now sounds fantastic. However, I've lately been having some issues with the reverb. With the bass up the spring tank rattles to the point that it's almost unlistenable. Additionally, with the reverb cranked I get a feedback that doesn't go away unless I turn the reverb off. That is, I can have the guitar volume all the way down and the feedback persists. Any ideas of what might be up?
djbarker is offline   Reply With Quote
Old December 21st, 2006, 09:28 PM   #2 (permalink)
TY
TY's Avatar
Sometimes a microphonic reverb driver tube will howl on its own. Swap some tubes around and see if it helps.
Welcome to the board.
TY is offline   Reply With Quote
Old December 21st, 2006, 10:34 PM   #3 (permalink)
Thanks TY - can I simply switch them or do they need to be replaced with something that isn't microphonic? If I just need to switch them, does it matter which 12ax7 I switch them with?
Old December 22nd, 2006, 06:56 AM   #4 (permalink)
Telenator's Avatar
It doesn't matter as long as the tubes are all 12ax7's. If I recall that amp may have a couple 12at7's in it which look exactly the same but will not sound the same.
I agree with TY, it's probably just a microphonic tube.
Dogs have the right idea!
Old December 22nd, 2006, 08:24 AM   #5 (permalink)
Stan Martin's Avatar
the reverb driver tube
should be a 12AT7 not AX7, the recovery tube should be a 12AX7. Also the phase inverter is a 12AT7.
Stan Martin is offline   Reply With Quote
Old December 22nd, 2006, 10:56 AM   #6 (permalink)
Thanks everyone - this is some great help for my first post. What about the rattle I'm getting? It's pretty much an exaggerated version of the sound you get when you stomp the floor next to an amp with a spring reverb. I can't play the wound strings without that noise when the reverb is on.
Old December 22nd, 2006, 05:02 PM   #7 (permalink)
add
some foam weather stripping to the tank cardboard bottom(shock absorber) and put back in the bag, also do NOT tighten the reverb bag down all the way. There needs to be some freedom of movement, if the bag is tightened down all the way, then every little motion will trigger the springs to rattle.
Old December 23rd, 2006, 05:46 PM   #8 (permalink)
exactly
Im really a Les Paul guy at heart, but .....
stevedenver is offline   Reply With Quote
Old January 9th, 2007, 11:17 PM   #9 (permalink)
I have done the weather stripping trick - worked beautifully. Unfortunately, the squeal with the reverb still persists at high reverb settings. I checked out the tubes, they're all a-okay. I've heard a couple of ideas from techs around. It's either: a bad reverb tank (looked good to me when I had it out of the bag to add the weather stripping), corroded reverb tank lead(s), or the reverb transformer. Let me know what you think.
Old January 9th, 2007, 11:57 PM   #10 (permalink)
I just had a similar thing with my Fender twin, the guy replaced the reverb transformer plus something else but it fixed it, it's the second time I have had the transformer go like that.
Clive Hugh is offline   Reply With Quote
vB code is On
Forums Directory
