Old September 3rd, 2003, 08:32 PM   #1 (permalink)
Small practice amp advice needed
I need your suggestions for a SMALL practice amp (15W or less. After doing some research on Harmony Central, I believe I will try the Pignose and VOX Pathfinder 10. Any other suggestions? My main amp is a 59 BMRI, way too loud for practicing. Style = blues, guitar = Tele. Thanks.
bluejamul is offline   Reply With Quote
Old September 3rd, 2003, 10:46 PM   #2 (permalink)
Why play around?
Fender Vibro Champ (aka Bronco) or Champ. Point-to-point wiring and a track record as one of the most recorded amps in history. A couple hundred for a silverface, maybe three hundred for a blackface. Upgrade the speaker, swap in a 3-prong electrical cord, and you're ready to go. It doesn't get much better.
John Harrison is offline   Reply With Quote
Old September 3rd, 2003, 11:12 PM   #3 (permalink)
I'll second that.......
Champ all the way,Big amp tone in a little package.
I use my '71 Vibro Champ for everything from Late night practicing to Gigs.
Why??
Because it sounds so good.
I have a couple other Vintage Fenders,but the Vibro Champ sounds better.Mostly because I've spent more time modifying it than the other amps I have.
The Champs are some of the best amps ever made.
Boom,Boom,Boom,Boom
-J.L. Hooker
Bluedawg is offline   Reply With Quote
Old September 6th, 2003, 12:57 PM   #4 (permalink)
Re: I'll second that.......
Bluedawg, what sort of mods did you do to your Champ? Can you make a SF sound like a BF or better yet tweed?
Old September 6th, 2003, 01:19 PM   #5 (permalink)
See below
The discussion with HippieTim. He ended up with a Blues Junior. Champ is less features, but you can't beat the basics it offers.
TexGoneNW is offline   Reply With Quote
Old September 6th, 2003, 10:08 PM   #6 (permalink)
Tweed??
Yes I can.Mine sounds extraordinary.
People go nuts over it.
Boom,Boom,Boom,Boom
-J.L. Hooker
Old September 7th, 2003, 01:07 PM   #7 (permalink)
rickyralph's Avatar
i cant help it so here i comes again
try a songworks little lanali amp there great sounding, look cool and not to many around so you dont have to be like every body else on the block. i love all things fender and marshall but sometimes its nice to play something else too!
no more small frets please!
rickyralph is offline   Reply With Quote
Old September 7th, 2003, 07:23 PM   #8 (permalink)
If you don't want...
or feel the need to drop a lot of coin the Vox is a suprisingly good choice. VERY compact, and portable with a decent sound at low to medium volumes, even has a few features that the Champ, PJ and others lack...A headphone/line out jack (actualy sounds good) alowing late night practicing/recording. A master volume..saves you from having to set up a pedal for a quick session.. (a unpedaled Champ is fairly loud at break up..depending on your situation this can be a problem)..not quite the sound quality of the Champ, but no tube worries, easy to order and comes with a warranty.
Loud is Good...
buglecorps is offline   Reply With Quote
Old September 8th, 2003, 02:22 PM   #9 (permalink)
The Actionman's Avatar
Not tubes...
...but sounds really good at bedroom levels:
Tech 21 Trademark 10!It does a really good tweed break-up at low volumes.
(Les Paul is playing the TM 60 for a couple of years now!)
Also records direct with a XLR and a headphone out.
I have many tube amps (mostly Fenders) that have to be cranked to get the tone I need for my blues, but for $200 on eBay, you'd be hard-pressed to find a better value and TONE. I have a TM10 and 60 now. Both are different amps and are solid state (yes, he admitted it! ) but have plenty of variation that has brought some new moods to my playing - somewhat of a rut I'd been in!
p.s. I also have a SF Champ that sounds great, but still makes too much noise/volume when the kids are sleeping and I get an hour to noodle!
Twang on!
The Actionman is offline   Reply With Quote
Old September 9th, 2003, 05:51 AM   #10 (permalink)
Rob DiStefano's Avatar
I'll triple that - can you say "Champ"? IMO, the best small PTP, Class A tube amp yer dollars can buy. As John sez, swap out the speaker, ground the power cord. You should be able to find a good Champ for $200, or less.
Old September 9th, 2003, 07:30 AM   #11 (permalink)
Boss Cube 30
Had a chance to hear a Roland/Boss Cube 30 the other night at rehearsal. Great sounds, modeling and effects for @$239.00.
It does some tweed/vox/blackface things, acoustic simulation. Has effects; verbs, delays, chorus, trem etc. It's loud evough to use on a gig with miking although 2 would be even better. As an old tube amp guy let's just say I was shocked.
roger is offline   Reply With Quote
Old September 9th, 2003, 08:04 AM   #12 (permalink)
I have a roland cube 30 and it's an excellent practice/small gig amp. The clean sounds are very good, the tweed and blackface sounds are very good, the marshall sound is good, and I guess the rectum-frier sounds are good--I never play that way. Better than a champ? I dunno, but it's good and it's cheap. Has a headphone out. I've used it on solo jazz gigs and it does very well. Thirty watts and a single ten puts out some serious volume
It doesn't sound as good as a good tube amp. But it sounds as close as a modeling amp can get, and it's cheap and seems well built
maxvintage is offline   Reply With Quote
