EL84's vs. 6L6's
I'm sure there's been a lot of discussion about this but I'm wondering what the differences are between the two.
I have Peavey Classic 30 (two 84's) and have been thinking about a more powerful amp like the Hot Rod Deluxe or DeVille - both of which use 6L6's I think. http://homepage.mac.com/davidniles/guitars/ |
Sonically and technically they're different but describing those differences are difficult since they are often used in very different circuits. Most EL84 amps are cathode-biased while most 6L6 amps are not; that alone has a major difference on the sound. EL84's also can't handle nearly as high a voltage as 6L6's which also has a very large effect on the resulting tone of the circuit. The same goes for preamp structures: It's much more common to find a multi-stage preamp (i.e., generating distortion) driving 6L6's than it is to find one pushing EL84's (a few Mesa amps use them though). So most people who describe the difference are liable to be describing the differences in the circuits rather than the tubes.
What I can say is that 6L6s give you more headroom, less break-up, and an overall cleaner tone. They also give you a lot more output power for a given # of tubes. Probably the best A/B comparison is to find one of the Mesa Nomad series; the lower power ones use EL84's while the higher wattage ones use 6L6's I think. Of course, the circuits are not identical but at least they're sort of in the same ballpark.
MJ Harnish Suburbs: Where they cut down all the trees and then name the streets after them. |
The 6L6 DeVille amplifiers will have only a few more watts, which you may not even hear. Try the pair in a side-by-side 'shoot-out'. Most music stores should let you do it, especially if you are a regular customer. Then, decide for yourself if the extra 'bulk' is worth it.
Standard Rant Alert! Opinions are like _________ (fill in the blank with any body part); everybody has at least one. For me, those Fender DeVille amplifiers seem to have trouble. I've seen many with 'bad' jacks, cold soldering, and the like. I've never owned one, but that's what I see. I have owned a Classic 50 since they first came out; and with no trouble other than tubes. The downside is this sucker is heavy (second only to my JCM800 combo). I'm sure the Classic 30 is also a great amplifier. I would keep it, and think about a more efficient speaker. It may be the ticket. It's tough to have a Cadillac that gets 100 miles-to-the-gallon. Getting a small amplifier that has some power (and tone) to it, without breaking your back and wallet, is everyone's quest.
"You can lead a horticulture, but you can't make her think!" |
#5 (permalink) | |
Well, I knew I was on the right track. I like Peavey, but like any other company, they think of their bottom line. Scrimping on the speaker can hurt your 'reputation', and now you know what I mean. It does depend on the music you play, too.
Blue Guitar has the schematic and layout; you may want to look at 'beefing' up the circuit, if you think there's room for improvement there. I did a few of the Classic 50 mods, and they work. If they are 'better' is a matter of taste and opinion, but it's great the information is out there. Look up the schematic and layout at http://www.blueguitar.org.
C30 speaker
For the most part I play Chicago blues and some Jump blues so it looks like the Weber California might be a little too clean. Of course I'm also learning a lot more country licks with my Tele and a good clean sound is paramount for that style. Then of course there's the R&R I play .... so many things for one amp!
#8 (permalink) | |
Re: C30 speaker
#9 (permalink) | ||
Re: EL84's vs. 6L6's
Best of luck, CS |
EL-84 Amps...
I service both the Peavey and the Fender products on a daily basis. The Peavey EL-84 amps sound great, though the reverbs are a bit lightweight, but they are notoriously not road worthy. They PCBs in those amps are built in three pieces..and they are thin. They are held together with very small bus wire. We see a lot of problems with this construction when amps are moved a lot. Also, some of the Peavey EL-84 amps have no protection for the tubes from being hit from the rear.
The Fender EL-84 product had a lot of bugs in it but is now pretty much bug free, now that the reverb problems are solved. BUT...there is one thing that all EL-84 products have in common and that is an epidemic of mechanical noise caused by sympathetic vibration with the speaker. The only EL-84 amps we don't see this problem in non combo amps (heads). It appears that well over half and maybe as many as 75% of all the new amps we see have this rattle problem in the output tubes. The Mfg's have attempted to solve the problem with tube retainers that attempt to damp the vibration but it doesnt totally solve the problem. The situation is so bad with our Peavey Classic 30 stock that we have even considered not selling the very popular amp....not likely though. NOS EL-84s are not so prone to this mechanical rattle but most all of the current mfg tubes are to one degree or another. I would consider this issue before I settled on an EL-84 powered amp. We see far, far fewer such problems from other output tube types. willie |
re: EL84 rattle
Yes, I often hear that rattle in my Classic 30 at certain frequencies. It's bothersome, but it doesn't seem noticable when I am playing on stage.
The reverb unit rattles in the car on the way to a gig - I wonder if that will kill the unit eventually? |
#13 (permalink) | |
Re: re: EL84 rattle
#15 (permalink) | |
Re: re: Weber California
