fundraiser
Old November 23rd, 2006, 02:28 PM   #1 (permalink)
Ivan's Avatar
Do many people use bass amps for guitar?
So let me establish myself... i play guitar, i dont gig, i play at home and use a POD for effects and amp modelling. My guitar amp is a Fender 15W Frontmam
I have a Gorilla 30w bass/keyboard amp (also a beginner amp) i wanted to sell on ebay. However when i tested it with my guitar to check its condition, i loved it!
Not just the sound, but ive been fustrated by my Frontman for a long time because of the loud hum it produces. Also i find the frontman is way too loud for my home use (the range in volume isnt very good, so i either get too loud or too quiet).
With the bass amp, i have more range with volume so i can get it at the level i want.
Ive decided to sell the Frontman instead and use the bass amp in conjunction with my POD.
So... any one use bass amps for guitars? (and isnt the Fender Bassman a bass amp?)
Ivan
__________________________
'06 Gibson Les Paul Standard
'06 Martin D-35
'06 Fender AV '62 Stratocaster (Wildwood Thinskin)
'05 Fender AV '52 Telecaster
Ivan is offline   Reply With Quote
Old November 23rd, 2006, 02:32 PM   #2 (permalink)
CancerLeoCam's Avatar
Some bass amps work wonderfully for guitar. Obviously, the Bassman started out as a bass amp but many loved it's sound flavor making it a staple for many prolific and not-so prolific guitar players.
Everyone's your buddy when they want you or something from you.
If you're not willing to work for free why should somebody else?
CancerLeoCam is offline   Reply With Quote
Old November 23rd, 2006, 06:42 PM   #3 (permalink)
aunchaki's Avatar
I use a 4x10 bass cab with different guitar heads for electric and acoustic guitar, I love it.
Two Teles, One Strat, Two Acoustics (6 & 12 strings), One Solidbody Acoustic,
Two Mandolins (4 & 8 strings), One Bass (5 strings)
aunchaki is online now   Reply With Quote
Old November 23rd, 2006, 07:03 PM   #4 (permalink)
I will, for some tracks.
My girl sometimes uses a guitar amp for some bass tracks too.
For home use, a POD into a bass amp could be plenty fine if it gets the sounds you want and helps you have fun.
Old November 23rd, 2006, 07:32 PM   #5 (permalink)
Dacious's Avatar
In this instance the POD is providing your tones - the amp is acting like a PA - just reproducing clean sound rather than providing 'input'. Your overdrive/distortion is coming off the POD - which is exactly how most modellers work.
The 4x10 Bassman was always a bit of a joke as a bass amp - 10" speakers with a lowest reproducible frequency of 71 hz, which is about fret 5 or 6 on the low-E of a bass guitar and goes down to 41hz.
The Gorilla, being an 'economy' amp probably has a full range 50-5khz speaker which will cover the range of a guitar amp, and the lower frequencies allowed in by the preamp design won't be used by the guitar anyway.
Old November 23rd, 2006, 07:37 PM   #6 (permalink)
'caster oil's Avatar
I really like the clean tones I get from my Tele through an SWR Workingman's 12, and use it frequently... not great for dirt, though...
"Capo on the fourth fret."
Keef
'caster oil is offline   Reply With Quote
Old November 23rd, 2006, 07:50 PM   #7 (permalink)
quackerz's Avatar
I remember watching Blues Traveler before they had a record deal in a little bar called Mondo Cane in NYC about a million years ago. Guitarist Chan Kinchla was playing a Strat through a solid-state Peavey MK IV (maybe it was a MK III) bass rig. The tone was so horrible that I never once thought to try plugging a guitar into my bass rig.
Some members here recommended that I try my Tele through my Ampeg B-15 before selling it to buy a guitar amp. I tried it. I sold the Ampeg. Just not my cup o' tea, I guess. YMMV.
quackerz is offline   Reply With Quote
Old November 23rd, 2006, 08:42 PM   #8 (permalink)
Rizo's Avatar
Older tube bass amps seem to work fine for guitar. The Bassman is the most obvious, but several Ampeg models as well come to mind.
I think as a general rule of thumb; small tube bass amps will work fine for guitar, while larger solid state ones do not work so well, IMHO.
"You say you want to play country, but you're in a punk rock band."
Rizo is offline   Reply With Quote
Old November 24th, 2006, 02:47 AM   #9 (permalink)
David Barnett's Avatar
If it sounds good it is good.
David Barnett is offline   Reply With Quote
Old November 24th, 2006, 09:14 AM   #10 (permalink)
Sarge's Avatar
I used to have a Roland 1X12 bass combo amp that I ran into a Traynor 8X10 bass cab. Great loud THUMPING tone. Kinda' big though to be draggin' around!
It sounded great with my strats and LP, this was before I got into tele's.
Sarge is offline   Reply With Quote
Old November 24th, 2006, 11:53 AM   #11 (permalink)
Do yourself a favor and get a Whirlwind ABY pedal. Plug your guitar into it, run one side into your Fender, and the other output plug into your POD setup. Set your speakers about 6 feet apart, and run the ABY pedal with both outputs on at once. You'll really like the combination of both amps running in stereo. If you really want grins, forget the ABY pedal and plug your guitar into a Boss Stereo Ensemble chorus pedal, and send one of the stereo outputs of your chorus pedal into the Fender amp, and the other output to the POD setup. Run your chorus on all the time. WhoooooEEEEEE Bob!!
sotto is offline   Reply With Quote
